5bikes Posted October 15, 2008 Share #1 Posted October 15, 2008 My 84 Venture Std. has this rear tire: 140/90-16 Michelin Hi-Tour A66, that came with the bike when I bought it last summer. It is a 71H. The wife and I are at maximum load without any "Stuff" in the bags. This tire is actually 148mm wide inflated. There is still more than 5 mm or .2" between the tire and the drive shaft housing. Any one tried a 150/90-16 rear? 1. It would have a higher load rating. 2. It theorically would be .4" wider (but mine is already 8mm or .3" wider), the speedometer would be 1.5 slower (more accurate) due to larger diameter .7" and circumference 2.2". (Plenty of room) On the front I could not use a larger tire. The fender is very close to the tire. But 65H is not overloaded. Link to comment Share on other sites More sharing options...
GeorgeS Posted October 15, 2008 Share #2 Posted October 15, 2008 Not enough clearance at the drive shaft, to increase the Width of the Tire. Look at the widest part of your tire, near the front of drive shaft houseing. Link to comment Share on other sites More sharing options...
5bikes Posted October 15, 2008 Author Share #3 Posted October 15, 2008 My present tire is 148mm plus 5mm clearance still would be 153mm. Any one got a 150/90-16 that could be measured? Link to comment Share on other sites More sharing options...
Stanman Posted October 15, 2008 Share #4 Posted October 15, 2008 I don't think the speedometer would read slower as they drive off the front wheel, unless your '84 is different. Link to comment Share on other sites More sharing options...
5bikes Posted October 15, 2008 Author Share #5 Posted October 15, 2008 But the engine speed would be about 1.5% slower. Not much. 71H=761Lbs. capacity. the 750# bike divided by 2 = 375# plus passengers of 380# =755. I'm thinking more than 1/2 of the bike is on the rear tire so we are are probably over loaded. Without carrying anything. Maybe this is why there are tire problems on some types. Metzlers coming apart, Bridgestones ?, Dunlops 404's with low miles of wear Has anyone had issues with being right at the load capacity? Actually how wide are 150's? Link to comment Share on other sites More sharing options...
Condor Posted October 15, 2008 Share #6 Posted October 15, 2008 Has anyone had issues with being right at the load capacity? Actually how wide are 150's? I run pretty close to 'theoretical' load capicity on my '83, and I'm probably always over the limit. The rear tire is the original Elite II that came with the bike when I bought it. I've never had a lick of a problem in 7-8,000 miles with the bulk of those miles being put on loaded down with travel gear. I think if you're really concerned about weight on the rear tire you might think about pulling a trailer where the tongue weight would only add around 50-70#. Link to comment Share on other sites More sharing options...
greg_in_london Posted October 15, 2008 Share #7 Posted October 15, 2008 You just need to look for a tyre with a higher load rating. Avon or Conti will do you one with a 77 Load Index which is good for 908 lb. You can download the Conti technical manual from http://www.conti-online.com/generator/www/de/en/continental/motorcycle/themes/download/technical_manual_uv.pdf but I've obviously no idea what availability will be like in your area. (Actually in the UK the Conti Tour is hard to get hold of at present - but that may not be the case for you.) I pull a lot of weight when we're on holiday - total weight about a tonne, so I get through back tyres fairly quickly - about 4,000 miles. No actual problems, though. Link to comment Share on other sites More sharing options...
GeorgeS Posted October 15, 2008 Share #8 Posted October 15, 2008 Dunlop E-3, MU90B16, fits your bike. Load rating is 930 lb. @ 40 PSI http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=86 Link to comment Share on other sites More sharing options...
Gearhead Posted October 20, 2008 Share #9 Posted October 20, 2008 Yeah, what George said. And an E3 should last 23k miles plus. Can't beat it! Jeremy Link to comment Share on other sites More sharing options...
ddoggma Posted October 20, 2008 Share #10 Posted October 20, 2008 The Kenda Kruz rear tire I just put on, sports a 77H rating as well. Very heavy duty tire and seems to ride real nice too. Price was good also. Got both front and rear for $137.00 shipped:thumbsup2: Link to comment Share on other sites More sharing options...
