Condor Posted May 9, 2007 Posted May 9, 2007 For all you Piggy Backers out there, I have a question. What brand/model ice chest did you find that would fit fairly close in the cooler rack on the standard?
sarges46 Posted May 10, 2007 Posted May 10, 2007 Jack What are the dimensions of the rack for yours...mine is 14 1/4" wide and 21 1/2" long on the xl piggybacker. Thats inside measurements.
Condor Posted May 10, 2007 Author Posted May 10, 2007 Jack What are the dimensions of the rack for yours...mine is 14 1/4" wide and 21 1/2" long on the xl piggybacker. Thats inside measurements. Thanks for checking Rick. Looks like my '06 standard is just a tad larger at 14.5"x22.25"on the inside I was just hoping that someone had found one that fit, and it would save me the trouble of carrying around the tape measure and checking everything I bump into that looks like it might be close... Now it looks like there are different sized cooler racks. Maybe I should give Piggybacker a call and see just what kind of cooler they used to do the moc-up.???... When in doubt...read the instructions....
sarges46 Posted May 10, 2007 Posted May 10, 2007 They sound like the same size...I just quickly measured with the cooler still on it and my eyes might not have seen exactly. My cooler is fairly small and fits with room for a bigger one...which I will check to see if one our other ones will fit.
Condor Posted May 10, 2007 Author Posted May 10, 2007 They sound like the same size...I just quickly measured with the cooler still on it and my eyes might not have seen exactly. My cooler is fairly small and fits with room for a bigger one...which I will check to see if one our other ones will fit. I just took a look at the their website and it gives the dimentions as 22x14, so I went ahead and wrote them asking about what ice chest they used for the design. We'll see if they get back to me. I'd just like to get one that comes reasonably close to taking up the whole space, or at least one that looks funky cool....like a Coke, Coors, or Bud cooler...
BradT Posted May 11, 2007 Posted May 11, 2007 I have a Gott 48 Fits perfectly in the bracket. I bought it many years back but still works great. Color is wrong but fits well. Brad Third Photo is Chaos but I am not sure what his is.
Condor Posted May 11, 2007 Author Posted May 11, 2007 I have a Gott 48 Fits perfectly in the bracket. I bought it many years back but still works great. Color is wrong but fits well. Brad Third Photo is Chaos but I am not sure what his is. I'll check out the Gott's. I received an email back from Tom at PiggyBacker and he mention an Igloo 36-40qt., but I have one of those, and it's 13x23 instead of 14x22. Close, but no cigar. He didn't have his notes at hand, but hopefully he'll get back to me later today with what they did use for a model. BTW, aren't Gott's orange, Coleman's blue, and Igloo's white... Chaos may have a Coleman?? Anyway later today I'll head on over to Walmart with my tape measure...
RSV Angel Posted May 12, 2007 Posted May 12, 2007 Condor, When I had Sarge's trailer here I checked the size also so KJV4 could get one for his. I have a blue Gott 48 that fits perfectly. The one in Sarges was a Rubbermaid and it had a little room around it. Just a side note--BradT and all who run with a cooler. If you turn the cooler around so it opens up from the back you don't have to worry about the wind getting under the lid and trying to open it going down the road.
Guest Chaos Posted May 12, 2007 Posted May 12, 2007 Third Photo is Chaos but I am not sure what his is. Mine is a Rubbermaid Model 985J which I beleive is a 48 qt. ?
Condor Posted May 12, 2007 Author Posted May 12, 2007 Condor, When I had Sarge's trailer here I checked the size also so KJV4 could get one for his. I have a blue Gott 48 that fits perfectly. The one in Sarges was a Rubbermaid and it had a little room around it. Just a side note--BradT and all who run with a cooler. If you turn the cooler around so it opens up from the back you don't have to worry about the wind getting under the lid and trying to open it going down the road. Thanks for the info Angel. Looks like I gotta get a Gott... The position of the lid opening had already crossed my mind, but thanks for the warning. Can you imagine what it would be like to have the lid come loose at 70mph:shock3: Another reason to have the hinge forward is at high speeds air could be blown in under the lip and the chest could loose it's 'cool' quicker than normal.....maybe??... I just did a websearch for a Gott 48 and found the dimentions. http://www.rubbermaid.com/rubbermaid/images/product/2a15_tm2.jpg 2A15 48 Qt Ice Chest Assembled Dimensions: 14.25" (H) x 23.75" (W) x 15.88" (D) Additional Product Information $34.95 I think the new one's going to be too wide for the basket.....??? I'll have to find one and measure the base as they all seem to taper a little toward the bottom.
wolfman1 Posted May 15, 2007 Posted May 15, 2007 Rubber Maid fits perfectly. I measured for mine and took a tape measure with me and found that a Rubber Maid will fit. It works great. Just face it backwards and put a small bunge cord across the top to keep it down if you hit a large bump or pot hole. Steve:080402gudl_prv:
Mean Dog Posted May 15, 2007 Posted May 15, 2007 Rubber Maid fits perfectly. I measured for mine and took a tape measure with me and found that a Rubber Maid will fit. It works great. Just face it backwards and put a small bunge cord across the top to keep it down if you hit a large bump or pot hole. Steve:080402gudl_prv: Next Question? What size rubber maid did you find that fit so well 38qt, 42qt? Dog
Condor Posted May 15, 2007 Author Posted May 15, 2007 What model is it Steve? I'm running into a wall on everything else. Seems like everybody has switched to a 13"x 23" to 23.5" wide on their new designs..... Maybe it's time for Piggybacker to change their jig setup.
Condor Posted May 15, 2007 Author Posted May 15, 2007 Next Question? What size rubber maid did you find that fit so well 38qt, 42qt? Dog I think I answered my own question. Went to Rubbermaid's site and it looks like the 34qt chest will be a close fit..... 34QUART
