Guest mudbucket Posted July 20, 2008 Share #1 Posted July 20, 2008 where can i buy a hitch at. are they available online. anybody expriencing a rattle sound maybe from the rear. sounds kind of like a disk pad rattle or squeak but thats not what it is. i have a 2008 venture. Link to comment Share on other sites More sharing options...
MAINEAC Posted July 20, 2008 Share #2 Posted July 20, 2008 I bought my hitch off of a member here who makes them... You won't find a better deal anywhere.. http://www.venturedad.com/RSV%20hitch.htm About the rattle check your trunk and mounts... all the bolts to your fender struts and those passenger grab rails... the rear grab rail bolts kept coming loose on mine... I finally took them off. Link to comment Share on other sites More sharing options...
Carbon_One Posted July 20, 2008 Share #3 Posted July 20, 2008 Also check the saddle bags and the hinges for the lids as they're know to work loose as well. Maybe check the trunk mounting screws while your at it. Look under the inner trunk pad for the screws. Larry Link to comment Share on other sites More sharing options...
Squidley Posted July 20, 2008 Share #4 Posted July 20, 2008 1 word of caution, if you find loose screws in the ABs plastic DONT USE LOCKTITE on them. It will make the ABS brittle and break. I have had a Venturedad hitch before and for the price thay are a great hitch. There are several others like the hidden hitch that Diamond R sells http://www.diamondraccessories.com/yamaha/proddisplay.php?name=Vertical%20Hide%20a%20Hitch Link to comment Share on other sites More sharing options...
