WIll 1987 Royal Venture gas tank fit on 1991 Royal Venture?
My 1991 Royal Venture gas tank needs to be replaced. I found a used 1987 gas tank on ebay that seller says will fit the 1991 venture but I wanted to confirm before I made the purchase. Any help will be appreciated. Thanks.
Yes Sir, Yes sir it is a positive fit!!
http://www.yamahapartshouse.com/oemparts/p/yamaha/54k-24110-00-33/fuel-tank-comp
Yes, it will bolt right in.
Although all First Gen Venture fuel tanks are interchangeable, they are not all identical. For instance, the 1983 and 1984 fuel tanks use a non locking gas cap (the fuel filler door locks). The 1985-1993 fuel tanks use a locking gas cap with a non locking fuel filler door. The 1985-1993 locking gas cap will NOT work on the 1983-1984 fuel tanks. The fuel tank neck/opening is different.
Just a FYI.
Your Welcome I will also ad that $12 a year is a darned good price for the knowledge you gain from such a site, there is a couple sites you can go in like boats.net partzilla.com If you have a part your looking for and see it on ebay, I use yamahapartshouse.com to cross reference parts if there in question. I believe partzilla and boats.net also you can do the same there. the reason I use yamahapartshouse.com is they still list all the parts even tho they have discontinued most.
Just a FYI.
See right there I just got schooled!!! I did not know that.. My bike is just Unique.
