ENG2242 Posted July 12, 2014 Share #1 Posted July 12, 2014 2013 RSV, where do they hide the CB and the stereo? Also, the CB antenna is supposed to be on the left if sitting on the bike, correct? Thank-you David Link to comment Share on other sites More sharing options...
Freebird Posted July 12, 2014 Share #2 Posted July 12, 2014 Stereo is inside the fairing. Sits right on top..or under...I don't remember...the Tape player. CB is in a black box under the trunk. Yes, CB antenna should be on the left side when you are sitting on the bike. Link to comment Share on other sites More sharing options...
ENG2242 Posted July 12, 2014 Author Share #3 Posted July 12, 2014 Thank-you, have a great day Link to comment Share on other sites More sharing options...
XV1100SE Posted July 12, 2014 Share #4 Posted July 12, 2014 Stereo is inside the fairing. Sits right on top..or under...I don't remember...the Tape player..... You really do need a 2nd Gen in your stable ! Link to comment Share on other sites More sharing options...
dacheedah Posted July 13, 2014 Share #5 Posted July 13, 2014 make sure the antenna with the load coil is on the left Link to comment Share on other sites More sharing options...
Rick Haywood Posted July 13, 2014 Share #6 Posted July 13, 2014 make sure the antenna with the load coil is on the left And that the set screw for the top half is tight........right Kevib:stickpoke: Link to comment Share on other sites More sharing options...
dacheedah Posted July 14, 2014 Share #7 Posted July 14, 2014 Absolutely Rick, as a note not the place for a flag, get a designated flag holder, in the long run its cheaper Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
a1bummer Posted July 15, 2014 Share #8 Posted July 15, 2014 And that the set screw for the top half is tight........right Kevib:stickpoke: And if you use a file to notch the antenna where the set screw pinches it, its much more likely to stay put if the screw does come a bit loose. Bill Link to comment Share on other sites More sharing options...
