rayzar52 Posted March 16, 2012 Share #1 Posted March 16, 2012 Need to remove old gas from a 1984 Venture is there an easy way to do this or do I need to get a Sifen pump of some sort, was told that just putting hi test new gas in was not a good idea. Link to comment Share on other sites More sharing options...
Keemez Posted March 16, 2012 Share #2 Posted March 16, 2012 Just pull the outlet line off the petcock and put a separate drain tube onto the fitting; put other end into container of your choice and turn the petcock to reserve. As for what sort of gas; you're not going to do any damage by running high octane through it- it just costs more to go up in fumes is all. If it's got ethanol in it (as most gas does these days) probably not a good idea to let it sit for an extended period; either ride it out or drain it out and then see if you can find stations in your vicinity that sell ethanol-free stuff. Link to comment Share on other sites More sharing options...
Snaggletooth Posted March 16, 2012 Share #3 Posted March 16, 2012 Two easy ways. Remove the fuel line from the petcock and run another piece of line from there to a container. Or ......... remove the fuel line from the feed side of the fuel pump and drain from there. Of course check the tank for rust before proceeding. You don't need Hi Test. Good old regular will be fine BUT add a good dose of Sea Foam to the new gas and let it sit in the carb bowls over night then run the daylight out of it. Mike Link to comment Share on other sites More sharing options...
jfoster Posted March 16, 2012 Share #4 Posted March 16, 2012 Just pull the outlet line off the petcock and put a separate drain tube onto the fitting; put other end into container of your choice and turn the petcock to reserve. As for what sort of gas; you're not going to do any damage by running high octane through it- it just costs more to go up in fumes is all. If it's got ethanol in it (as most gas does these days) probably not a good idea to let it sit for an extended period; either ride it out or drain it out and then see if you can find stations in your vicinity that sell ethanol-free stuff.[/quote Try your local bulk plant for non-ethanol gas. Ours recently started carrying it. Very few stations carry it down here. Link to comment Share on other sites More sharing options...
rayzar52 Posted March 16, 2012 Author Share #5 Posted March 16, 2012 Thanks guys I totaly forgot that the84 had a reserve, because I have a 2007 RSV now. I am just getting the 84 running smooth for selling, it was my first and if I had room and didn't mind a divorce I would be tempted to keep her, but you know wife doesn't mind one mistress but tow might be to much . Just saying. RIDE SAFE and RIDE FREE Link to comment Share on other sites More sharing options...
darthandy Posted March 16, 2012 Share #6 Posted March 16, 2012 Thanks guys I totaly forgot that the84 had a reserve, because I have a 2007 RSV now. I am just getting the 84 running smooth for selling, it was my first and if I had room and didn't mind a divorce I would be tempted to keep her, but you know wife doesn't mind one mistress but tow might be to much . Just saying. RIDE SAFE and RIDE FREE My 2000 RSV has a reserve. Are you saying your '07 does not? I thought they all did right up to the latest version? Andy Link to comment Share on other sites More sharing options...
rayzar52 Posted March 16, 2012 Author Share #7 Posted March 16, 2012 no I forgot that the 84 did Link to comment Share on other sites More sharing options...
KIC Posted March 16, 2012 Share #8 Posted March 16, 2012 Be careful turning the reserve petcock. From what I have read in other posts, the petcock valve rod can stick/jam and can break if it hasn't been used a lot. Mine won't turn. I haven't gone in to see what the issue is, but just don't force it. Link to comment Share on other sites More sharing options...
