Freeman50 Posted July 27, 2010 Share #1 Posted July 27, 2010 What carb can i use on my 1983 venture that i can bolt it on and just go:confused24: Link to comment Share on other sites More sharing options...
skydoc_17 Posted July 27, 2010 Share #2 Posted July 27, 2010 Hey Rick, You are looking for a set of Carbs. from any of the 1200c.c. motors, 1983 to 1985. Keep in mind that when replacing one of the Carbs, they will be location specific, in other words, a right front Carb. will not fit the left rear position. Good luck with your project, Earl Link to comment Share on other sites More sharing options...
Condor Posted July 27, 2010 Share #3 Posted July 27, 2010 What carb can i use on my 1983 venture that i can bolt it on and just go:confused24: I'm just assuming here, but I think you mean the entire 4 carb assembly. The '83 was sort of a 'beta' model, and unfortunately the only 'bolt and go' set would be from another '83. Other sets can be run, but they take a little more than bolt and go.... Link to comment Share on other sites More sharing options...
