I just got the bike back with my new Rivco Hitch, ( Honda Goldwing) I gave the tech's the sub wire harness, and Isolator & a 5 into 4 wire harness.
Question: shouldn't there be 4 wires coming to the back of the bike?
I have 5 Brown, Blue, Black, Green & Orange. Did they wiring this wrong?
How do i fix this, I have a 4 flat Plug in the trailer
Mike,
I think the extra wire is for the back up lights, you will need those when you put the GW in reverse to back the trailer into a spot. You did get the back lights as an option on your trailer , right? :rotf:
Guest tx2sturgis
Mike,
No no, its the power lead for the espresso maker.
Dontcha know nuttin?
:p
without going nutz over this, Is there a 5 into 4 (trailer wiring) adaptor I can install?
I just replaced mine, I bought a Hobson powered one form Auto Zone http://www.autozone.com/autozone/parts/Hopkins-Trailer-Tail-Light-Converter/_/N-8ijmg?itemIdentifier=70605_534335_0_
It says it's waterproof but if you mount it under your draw bar like I did it will get water in it and fail, probally because something from the road put a hole in the side of it.
:p
actually you're right, the Blue wire is for accessories ( OR ) a back up light:clap2:
