Saddle tramp Posted August 18, 2015 Share #1 Posted August 18, 2015 Is there hope to find a good speaker that won't distort over a whisper?It suck's that the aftermarket ignores us.Can not believe how any model Harley has limitless accessories.I can not afford the buy in or up keep of H-D,that is OK I love my bike.I just want a better speaker that I can hear when moving.There has to be something better than O.E.M. speakers. Link to comment Share on other sites More sharing options...
Freebird Posted August 18, 2015 Share #2 Posted August 18, 2015 It has nothing to do with the aftermarket ignoring us. There are plenty of speakers out there in the correct size. The problem is, the correct size is just not a large enough speaker and a larger one won't fit. Link to comment Share on other sites More sharing options...
BratmanXj Posted August 18, 2015 Share #3 Posted August 18, 2015 Most good brand 4" marine speakers with a real cone (not paper) and tweeter will be an improvement. But as Freebird stated it's still only a 4" speaker and there's only so far you can go with that small of a cone. I've been waiting for winter to split my fairing and install Blaupunkt MSX402 speakers, about $55 on Amazon. Link to comment Share on other sites More sharing options...
flynvy5 Posted August 20, 2015 Share #4 Posted August 20, 2015 I purchased a set of pioneer 4" from walmart. They are listed as water resistant but have a much higher power rating than stock. Link to comment Share on other sites More sharing options...
videoarizona Posted August 20, 2015 Share #5 Posted August 20, 2015 Is there hope to find a good speaker that won't distort over a whisper?It suck's that the aftermarket ignores us.Can not believe how any model Harley has limitless accessories.I can not afford the buy in or up keep of H-D,that is OK I love my bike.I just want a better speaker that I can hear when moving.There has to be something better than O.E.M. speakers. I'm running these. The only distortion I hear is the amp at high levels. These can handle far more than the amp will ever put out. http://www.carid.com/boss-audio/4-4-way-phantom-series-250w-speakers-mpn-p454c.html?gclid=CjwKEAjwndqrBRC16IyeqPicp3ASJAB-vB-cwk3ik9wd7RI4r_UrZ7Il4KMYLWlMBx7fX7P6JkRGBRoC9-jw_wcB or http://tinyurl.com/obetgh2 P.S. Still not much bass due to small size and placement...but I'm going to experiment with some fiberglass batting packed in fairing...maybe that will help. If not, I'll try and make a very light box to seal the backside of the units in. The speaker guru's I used to know back in the days of AR/Dynaco aren't alive so I can't ask them about porting, etc.. Not the simplest, but best idea, would be to build a fiberglass dam that contours to the inner side of the outer fairing with batting in it...then when the outer fairing is screwed on, it makes a sealed box around the speakers. Thinking out loud here... Hope this helps... david Link to comment Share on other sites More sharing options...
