lonestarmedic Posted September 9, 2008 Posted September 9, 2008 Does anyone have the numbers to the upper and lower bearings and races for the triple tree. I want to minimize down time and reduce costs a bit. After my little shake and bake, I won't feel comfortable until I replace them. Oh, Mavrik:stickpoke: - about that keeping 1st Gens out front so you wouldn't run away from them. Masterguns said to remind you that my death wobble hit at 110mph in 4th gear. And you know my speedo is right on because we checked it against your GPS that morning several times. I think the wobble got triggered by cutting across the air wake from the front of the semi. I remember a slight gust as I replay the bronco ride. THat and a groove or tar snake would have started it. Weird but un-nerving. JB
pegscraper Posted September 18, 2008 Posted September 18, 2008 A dealer should be able to get these part numbers. Are you wanting to order them yourself? Highland's Yamaha has prices as good as anyone. Their site uses the same parts diagrams as Y's own website. You should be able to find the parts you need there.
Squeeze Posted September 18, 2008 Posted September 18, 2008 Industrial Bearings Numbers are 32005X and 32006X. Buy some good industrial Brand Bearing and you'd be good to go. But you will have to salvage the Seal on the Lower Bearing from the old Set.
