MickO Posted August 18, 2008 Posted August 18, 2008 I was wonder which model of Harbor Freight trailers most people are using. I found this model on their web site. I was wonder if anyone had experience with this particular model or what thoughts folks might like to share. Thanks in advance. MickO http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42708
kwisor Posted August 18, 2008 Posted August 18, 2008 i have one pulls just fine no problems if you get it you will like it kevin wisor 1999 rsv jax fl
Eck Posted August 18, 2008 Posted August 18, 2008 That is the same one I looked at when at Harbor Freight this past saturday. I have heard where some have made the trailer not as wide.... by cutting the croxx members down the same length. This way the trailer dont stick out as far on each side of the bike (air turbulance -friction / gas mileage issues). I've also heard where some have moved the center cross member towards the front to extend the length of the neck...(8 to 9 inches). Guess the actual size you want it to be when completed would be YOUR design, based on YOUR reasoning. Some leave it as is and away they go.....and have no problems..as already stated. Proportionately, the actual width and length of the "carrier" you get to place on the top of the frame, would be "key" as to how wide you would need the trailer frame to be.. It would look some what funny to have a large frame base, and then have a small cargo carrier mounted in the middle of a piece of plywood.... of course this is only MY opinion now...which may not carry much weight with your actual end result design plans. good luck in what ever width / length you make it to be..... If uncertain as to how wide or long you want it.......leave it big and work your way down to what size you think you would actually want... You can easily "take away" material......but adding it would be a bit of a challenge with out having access to a welder..and some steel framing..
Skid Posted August 18, 2008 Posted August 18, 2008 That is the same trailer I am waiting on here, except I am getting mine at 15% off the sale price of $139.00..... Hopefully it will be here soon. I have my rain-check in hand!
MickO Posted August 18, 2008 Author Posted August 18, 2008 Skid: Where did you find the HF trailer for the price you indicated? As you can see from the link in the earlier post, the current price on-line is $229. You "done good" to pick up the trailer for $139 plus the discount. MickO
mini-muffin Posted August 18, 2008 Posted August 18, 2008 They sometimes put the trailers on sale. That's what happened when we got ours. It works out great no matter what you do with it. We've enjoyed ours. Margaret
flb_78 Posted August 19, 2008 Posted August 19, 2008 I got the one with 12 inch wheels. I figgered that if I ever needed to buy 1, 12 inch is easier to find, but now that I've seen these tires, I dont think it's necessary. These tires are so hard, that you could run them flat and almost not notice it. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90153
