igya Posted August 4, 2008 Posted August 4, 2008 This is a repeat of a reply I offered to a sad soul and thought it to be important enough to post a new thread so that everyone might benefit. This doesn't have to happen. Support the flat sided filler spout with a 16mm open wrench and turn against the 16 with a 14mm on the plug's hex head. That way you are neutralizing the stress placed on the thin sides of the pot metal fluid reservoir. Replace the plug with a brass or nylon washer and just snug it down. End of story.
V7Goose Posted August 4, 2008 Posted August 4, 2008 Is this a 1st gen thing, or what? I do not recognize the item to which you refer. Goose
Dano Posted August 4, 2008 Posted August 4, 2008 On the 1st gens, the rear brake reservoir is mounted above the master cylinder. It has a 14mm fill bolt located right near the corner of the unit. He is describing a good way to remove this bolt without breaking the reservoir. Dan
V7Goose Posted August 4, 2008 Posted August 4, 2008 Thanks for the reply - I'll move this thread to the 1st gen tech talk forum for clarity. Goose
cjacobs Posted August 4, 2008 Posted August 4, 2008 just incase you want to see what this looks like.............................
Yammer Dan Posted August 4, 2008 Posted August 4, 2008 Ouch!! I had to get into mine right after I read about the broken one. It was TIGHT!! Scared to death it was going to break. Once it broke loose it came out easy. You saying nylon or brass washer will stop it this?
Dano Posted August 5, 2008 Posted August 5, 2008 Yeah, keeps the bolt head from seizing to the pot metal on the reservoir. Dan
