Dusty Posted April 19, 2007 Share #1 Posted April 19, 2007 I have an old Motocomm headset that I used on my V-star connected to a small CB. Does anyone know if I can get an interface connection cable to hook up between that and the 5 pin Yamaha connector? I will eventually go for a J&M set but for now I'd like to use the existing headset I have. Any info is appreciated. Link to comment Share on other sites More sharing options...
sarges46 Posted April 19, 2007 Share #2 Posted April 19, 2007 J+M might have what you need or Edsets may make something if they dont have it. Link to comment Share on other sites More sharing options...
Eddie Fulmer Posted April 20, 2007 Share #3 Posted April 20, 2007 Me thinks you might have better luck finding hen's teeth:080402gudl_prv: Link to comment Share on other sites More sharing options...
stardbog Posted April 20, 2007 Share #4 Posted April 20, 2007 I Use to have Autocom Headset and never found stuf to interconnect Autocom And 5 Pin Venture set. Better take look on this web site and buy this headset. http://www.wingstuff.com/pgroup_detail/40_Home_Monthly_Specials/2310_J_M_HS8154_Headset_for_Goldwing_w_1Piece_Cord/?goto=%2F I Have now in my two helmets and sound quality is GREAT. Link to comment Share on other sites More sharing options...
Guest gitarzan Posted April 22, 2007 Share #5 Posted April 22, 2007 I've that same JM set. No complaints, esp. for that price. Link to comment Share on other sites More sharing options...
Guest r-retzke Posted November 4, 2007 Share #6 Posted November 4, 2007 An Autocom headset can work with the Venture and similar DIN 180º 5-pin systems. This attachment shows how. Rog in NH [ATTACH]13285[/ATTACH] Link to comment Share on other sites More sharing options...
Guest Kurt Leopold Posted April 13, 2008 Share #7 Posted April 13, 2008 where can I find who sells the edsets I see mentioned? Link to comment Share on other sites More sharing options...
Freebird Posted April 13, 2008 Share #8 Posted April 13, 2008 http://www.edsets.com/ Link to comment Share on other sites More sharing options...
george c Posted April 14, 2008 Share #9 Posted April 14, 2008 http://www.edsets.com/edsets_adapters Link to comment Share on other sites More sharing options...
DragonRider Posted April 14, 2008 Share #10 Posted April 14, 2008 I have that setup on my Vstar 1300 and I tried to swap speakers for better sound quality and found out that my J&M had 3 wire speakers vs 2 wire for the MotoCom. setup, I also tried a converter plug, that didnt work either, They must use a different wiring for the mike and speakers than the J&M, if you do succede, please let me know, I havent been able to find anything, so I have to have 2 helmets with different headsets, 1 for each bike. Good Luck. I have an old Motocomm headset that I used on my V-star connected to a small CB. Does anyone know if I can get an interface connection cable to hook up between that and the 5 pin Yamaha connector? I will eventually go for a J&M set but for now I'd like to use the existing headset I have. Any info is appreciated. Link to comment Share on other sites More sharing options...
