I build various break out harnesses for lighting systems, rear brake and turns, inside the fairing turns, aux power system and behind the rear tag jumper adapters.
Also I have a rear  light bar system that mounts under the trunk.
I also build trailer harnesses for 4, 5 and 6 wire systems, completely plug and play no cutting or splicing of wires.
Photos to come in the near future.
PM  me for details.
  • Like 2
Some pictures as promised.
Venture rear lighting breakout harness.
5 wire trailer harness with isolator
4 wire trailer harness with isolator.
  • Like 3
  • 4 months later...
I build light bars for Ventures, you could attach one to the cargo tray if you wanted to, it will give you tail lights, brake lights and turn signals.
In this photo it is mounted under my trunk. Completely plug and play.
I have used your harnesses before; they are awesome! Was struggling with what I thought was a harness problem recently; turned out to be the stator, but your relays and harnesses are installed on this trike. Considering talking to you about more lights; will start a new thread about it. My brother died an hour ago; I'm a bit preoccupied right now.
