ca_mccar Posted July 2, 2025 #1 Posted July 2, 2025 Hello all, im replacing the stator in my 86 Venture. When i took the cover off the starter gears fell out. I put the gears back in there place but there is a rogue washer that seems to put the splined gear shaft(with the 2 gears) Where does washer go? Do the starter gears have a washer? I checked parts diagrams but havent had any luck thank you!
RDawson Posted July 2, 2025 #2 Posted July 2, 2025 It’s been several years since I had one apart and don’t remember but the parts diagram doesn’t show one.
cimmer Posted July 3, 2025 #3 Posted July 3, 2025 I have checked my manual and parts fiche and I dont see any washers listed either. I might be temped to use them between the splined gears to space out the geas to make sure they mess with the opposite gear fully if needed. I replaced my starter clutch a number of years ago but dont remember any washer but my memory isnt what is use to be. Sorry I couldnt help more. Good luck Rick F.
Marcarl Posted July 3, 2025 #4 Posted July 3, 2025 IMHO there should be a washer between the gear and the aluminum case 1
