Junior Posted October 25, 2023 Posted October 25, 2023 Would like some pro and cons of adding risers.
M61A1MECH Posted October 25, 2023 Posted October 25, 2023 The one issue I had when I installed risers on my 2007 Venture was that the rubber supports between the bars and the top of the triple tree no longer supported the handle bars. Without the supports the bars seemed to flex a bit more. Some folks managed to turn them around but I fashioned a spacer of sorts, but I cannot find my photos of the 07, it has been gone for a long time. The risers did cure the shoulder ache issue I was having with the stock risers. If you have a 2005 to 2010 Tour DeLuxe I am pretty sure there are no risers for those models.
Junior Posted October 25, 2023 Author Posted October 25, 2023 Thanks for giving me your info. 2000 royal star venture is what I was thinking about using these on.
luvmy40 Posted October 26, 2023 Posted October 26, 2023 Depending on the height/pull back of the risers, you may have to reroute or replace your cables/hoses.
Junior Posted October 27, 2023 Author Posted October 27, 2023 Thanks for your response, I ordered a set of barons risers. I will follow up with how it helped.
