DonnyRudeDude Posted October 5, 2023 Share #1 Posted October 5, 2023 (edited) See below Edited October 5, 2023 by DonnyRudeDude Messed up and sent too soon Link to comment Share on other sites More sharing options...
DonnyRudeDude Posted October 5, 2023 Author Share #2 Posted October 5, 2023 3/4 of my instrumentation lights are blown. I can see the tach at night but that’s it. Can you explain how to access these lights? Do I need to remove the dash assembly to replace the blown lights? Thank- you, Mark Link to comment Share on other sites More sharing options...
Pasta Burner Posted October 5, 2023 Share #3 Posted October 5, 2023 I don’t know for sure but given it’s age and technology at the time and cages I’ve worked on I’d say yes Link to comment Share on other sites More sharing options...
DonnyRudeDude Posted October 5, 2023 Author Share #4 Posted October 5, 2023 Ok, Pasta Burner, thank-you. I have a VR parts bike I may practice on before I attempt it. I've seen on You Tube where the instrumentation panel is removed to fix the howling speedometer so I'll follow that process and lube the speedometer while I'm at it, Mark Link to comment Share on other sites More sharing options...
Marcarl Posted October 6, 2023 Share #5 Posted October 6, 2023 11 hours ago, DonnyRudeDude said: Ok, Pasta Burner, thank-you. I have a VR parts bike I may practice on before I attempt it. I've seen on You Tube where the instrumentation panel is removed to fix the howling speedometer so I'll follow that process and lube the speedometer while I'm at it, Mark I did grease that speedo, and the cable. Wonder what is causing that now. Special tool needed for the speedo. Link to comment Share on other sites More sharing options...
DonnyRudeDude Posted October 6, 2023 Author Share #6 Posted October 6, 2023 Hi Carl, the 84 VR is running great (Thank you) I was referring to my 86’. I lubed the cable but no effect. I was hoping to see you on the Ontario ride to pick your brain on this one. Mark Link to comment Share on other sites More sharing options...
Marcarl Posted October 7, 2023 Share #7 Posted October 7, 2023 21 hours ago, DonnyRudeDude said: Hi Carl, the 84 VR is running great (Thank you) I was referring to my 86’. I lubed the cable but no effect. I was hoping to see you on the Ontario ride to pick your brain on this one. Mark You need a cable lube tool, and then you have to get at the back of the speedo to use it for it's purpose. Link to comment Share on other sites More sharing options...
