jneed53 Posted May 29, 2023 #1 Posted May 29, 2023 Hey all, it’s been a while since I was last on here. I haven’t been riding much the last few years. About two years ago I had Big Red’s carbs redone along with all fluids changed. After all that I let her just sit long enough for, I think, the fuel to go bad. It starts but, as soon as I try to turn off the choke and/or give even the slightest throttle the engine dies. Anyone in the San Antonio area have insight for me?
Marcarl Posted May 30, 2023 #2 Posted May 30, 2023 Spray a can full of carb cleaner into about 1/4 tank of fuel, let it run until it's warm. Do this 4 times and see if it make an improvement. Use the spray stuff, I find it works much better than the pour in stuff.
Rodburner Posted Friday at 02:17 AM #3 Posted Friday at 02:17 AM On 5/30/2023 at 5:28 AM, Marcarl said: Spray a can full of carb cleaner into about 1/4 tank of fuel, let it run until it's warm. Do this 4 times and see if it make an improvement. Use the spray stuff, I find it works much better than the pour in stuff. so you need 4 cans of cleaner?
Marcarl Posted Friday at 02:05 PM #4 Posted Friday at 02:05 PM 11 hours ago, Rodburner said: so you need 4 cans of cleaner? Nah, 1 can. Warm and cool engine 4 times to get the cleaner to soak.
BlueSky Posted 6 hours ago #5 Posted 6 hours ago On 5/30/2023 at 8:28 AM, Marcarl said: Spray a can full of carb cleaner into about 1/4 tank of fuel, let it run until it's warm. Do this 4 times and see if it make an improvement. Use the spray stuff, I find it works much better than the pour in stuff. I thought carb cleaner would damage the rubber seals and the fuel needle tip which is rubber usually.
Marcarl Posted 6 hours ago #6 Posted 6 hours ago 23 minutes ago, BlueSky said: I thought carb cleaner would damage the rubber seals and the fuel needle tip which is rubber usually. it might if it wasn't diluted.
