SECOND GEN. S.S. BRAKE AND CLUTCH UPGRADE LINE SET!
WITH THE SECOND GENS. BEING OUT OF PRODUCTION SINCE 2013, THIS MEANS THAT THERE COULD BE SECOND GENS. OUT THERE WITH BRAKE AND CLUTCH LINES THAT ARE 24 YEARS OLD! IN AN EFFORT TO KEEP THESE BIKES SAFELY ON THE ROAD, I HAVE CREATED A REPLACEMENT BRAIDED S.S. LINE TO REPLACE EVERY BRAKE AND CLUTCH LINE ON YOUR MOTORCYCLE.
THIS S.S. LINE SET IS A DIRECT BOLT ON REPLACEMENT, THAT REQUIRES NO MODIFICATIONS TO THE BRAKE OR CLUTCH MASTER CYLINDERS OR THE CLUTCH SLAVE CYLINDER OR BRAKE CALIPERS! IN THE PIC BELOW THE LINES ARE MARKED “A” THRU “E”.
LINE A- LOWER RIGHT AND LEFT FRONT BRAKE CALIPER LINE.
LINE B- REAR BRAKE CALIPER LINE.
LINE C- UPPER BRAKE MASTER CYLINDER LINE.
LINE D- UPPER CLUTCH MASTER CYLINDER LINE.
LINE E- LOWER CLUTCH SLAVE CYLINDER LINE.
THE COST FOR THIS S.S. LINE SET IS $250.00 WITH FREE SHIPPING IN THE LOWER 48 STATES. OUT OF THE COUNTRY SHIPPING WOULD BE ACTUAL SHIPPING COSTS. I DON’T MARK UP SHIPPING COSTS FOR THE INTERNATIONAL FORUM MEMBERS! I ACCEPT PAYPAL AND PERSONAL CHECKS FOR PAYMENT. I CAN ALSO PROVIDE R1/R6 4 PISTON CALIPERS AND HIGH PERFORMANCE BRAKE PADS TO FURTHER INCREASE THIS UPGRADE!
THANKS FOR VIEWING MY AD! SKYDOC_17.
  • Like 2
  • 4 weeks later...
Just curious. Can you provide same set extended (i.e. +2", 3", or 4". I do understand that there would be an increase in price. If not, who would you recommend for purchase? I am thinking about adding 1-1/2" risers, but haven't decided on the pull back or bars yet.
Thanks. Beak
Hey Ron,
This is a VERY Good Question! I am more than Happy to adjust the length of the Brake and Clutch Lines to accommodate Risers or Handle Bar Changes! Feel free to PM me with ANY adjustments you would like to make to one of my Line Sets!
Earl.
  • 2 years later...
Hi @skydoc_17 I am interested in a set of these for my 2012 RSV when possible & also sent you a message. I see these were listed in 2023, so hopefully you still have some available. Thank you & look forward to hearing back from you!
  • 9 months later...
  • 3 weeks later...
  • 3 weeks later...
