Jim Stanfill Posted June 21, 2022 Posted June 21, 2022 Whenever either right or left turn signal is used the 4 turn signals all flash help.
Marcarl Posted June 21, 2022 Posted June 21, 2022 Check the 4way flasher switch, located right of the steering column on the left side of the faring. Kind of hard to see and find.
saddlebum Posted June 21, 2022 Posted June 21, 2022 The the turn signal switch itself may have to be taken apart. An accumulation of green corrosion combined with wear fillings from the contact could be causing a cross feed of currant. It is easy to do but put an old pile carpet under the bike in case something drops. Little springs and other little things can quickly drop and bounce into oblivion.
