Dutch Navigator Posted August 7, 2021 Share #1 Posted August 7, 2021 I'm working on my 2005 Yamaha Royal Star Venture XVZ 1300 TF. Does anyone knows how much oil the back shock is holding? Peter Link to comment Share on other sites More sharing options...
Marcarl Posted August 8, 2021 Share #2 Posted August 8, 2021 Alles Link to comment Share on other sites More sharing options...
RDawson Posted August 8, 2021 Share #3 Posted August 8, 2021 @dfitzbiz 1 Link to comment Share on other sites More sharing options...
dfitzbiz Posted August 11, 2021 Share #4 Posted August 11, 2021 I've been away for a while. After I drain all of the oil and replace the bottom O ring I replace the oil with 125ml of Honda 10w Suspension Fluid. I use a cheap ($5) meat injector from Walmart to replace the oil. After removing the needle it screws directly onto the schrader valve. I've attached O ring replacement instructions, a photo and a drawing of a simple tool I designed to make the job easy. PM me with any questions you may have. RSV Shock Repair Overview With Special Tool.docx 2 Link to comment Share on other sites More sharing options...
Dutch Navigator Posted August 21, 2021 Author Share #5 Posted August 21, 2021 Thanks! This will work. Link to comment Share on other sites More sharing options...
