pick Posted May 10, 2008 Posted May 10, 2008 :think:Installing the Stebel horn, removed my old Rivco's. Questons is that will the relay that comes with the rivcos work with the Stebel? I tested it and it semed alright? Do I need to replace it with the Stebel relay for loudness or is it the same with the Rivco relay? Also, it seems even with the mount from Carbon One that that the wires are really close to the exhaust? Is this a problem? confused................................
KeithR Posted May 10, 2008 Posted May 10, 2008 (edited) The Stebel comes with a 30 Amp relay so as long as the one you had is the same I don't see why you would need to change it.....unless you want to install the newer one. I just installed mine and I was able to move the wires back from the exhaust ..... did you remove any wire ties from the original horn wires ? The side cover kinda moved mine away from the pipes. This is what Craig is referring to Edited May 10, 2008 by KeithR
cecdoo Posted May 10, 2008 Posted May 10, 2008 Dont use spade connectors on stebels, drill 2 holes in rear of black plastic, thread wires thru holes and solder to posts, then fill area with clear silicone, cant take credit for the idea, another guy on here suggested it, and it works great, keeps wires away from pipes. Craig
pick Posted May 10, 2008 Author Posted May 10, 2008 Thanks, I went ahead and istaled the stebel relay, not as tough as i thought (electronically deficient) Am seriously thinking of doing that very thing, I don't like the wires sooo close to the pipes........................... I guess I need a solder gun.................See above (electronically deficient) LOL
1BigDog Posted May 10, 2008 Posted May 10, 2008 I used 90 deg spades underneath the horn and covered them with liquid tape. I mounted my relay under the right side battery cover by double sided tape. I located it under that diode looking thingy. I then routed my wires out of the battery cover toward the front/center of the cover with enough slack to cable tie them away from the pipes and engine. BEEP BEEP
