ken5124 Posted June 30, 2019 Share #1 Posted June 30, 2019 Hey everyone, does anyone have a working CLASS controller for an 86 venture royale they would be willing to sell. ? I have the E1 error, attempts to check solder joints produced no change/ still only get the error message. Thanks Ken Link to comment Share on other sites More sharing options...
videoarizona Posted July 1, 2019 Share #2 Posted July 1, 2019 Kevin Campbell @Prairiehammer came up with this list: "E1" error may encompass a broad range of defects. Faulty connections. Faulty discharge valve (solenoid). Low pressure sensor input voltage. (Low battery or low voltage due to poor connectors) Faulty pressure sensor. And finally, incomplete solder repair at the nine pin board connector. Link to comment Share on other sites More sharing options...
Marcarl Posted July 1, 2019 Share #3 Posted July 1, 2019 I have tried to resolder that connector a number of times, sometimes it just doesn't work to re-flow the solder, you actually have to desolder and then apply new solder. That might help ya. Link to comment Share on other sites More sharing options...
ken5124 Posted July 2, 2019 Author Share #4 Posted July 2, 2019 Thanks, MY re solder seems to have worked.. Now to redo the front steering head bearings and put all of it back together ! Link to comment Share on other sites More sharing options...
CaseyJ955 Posted July 2, 2019 Share #5 Posted July 2, 2019 Thanks, MY re solder seems to have worked.. Now to redo the front steering head bearings and put all of it back together ! THAT will probably make a nice difference. I replaced my races and bearings with All Ballz racing parts, very pleased. If your lucky you can clean/grease/adjust. Theres a great video on youbute about Venture steering bearing adjustment, it dates back to the 80s and you will know it when you see it, the 80s cop mustache and porn quality dub give it away, but it's a super helpful video on where the adjustment should land. Glad the re solder worked! It's nice to have that functioning. Link to comment Share on other sites More sharing options...
ken5124 Posted July 4, 2019 Author Share #6 Posted July 4, 2019 Thanks Casey.. Lower bearing is now reinstalled, let the fun begin! The top bearing was quite notchy, so there should be a big improvement.. doing the front wheel bearings as well while it is apart. Link to comment Share on other sites More sharing options...
