RedRider Posted June 30, 2019 Share #1 Posted June 30, 2019 Goldenrider's '83 sprung a leak in the steel portion of the clutch line. We are trying to get on the road to Bryce Canyon and beyond. After several frantic PMs, texts, and ultimately a phone call from the Pucster himself, we formulated a plan. It uses standard 3/16 steel brake line with metric fittings. Picked up said brake line, hit HF for a pipe cutter and tube bender, and got to work. Should know more shortly as we haven't bled it yet. Getting a canopy from Walmart as there is no way this WI boy can work in the Phoenix sun. Thanks to VideoArizona and Cowpuc. We really appreciate your help. Will get pictures later as I can't seem to insert them from my phone. RR Link to comment Share on other sites More sharing options...
videoarizona Posted July 1, 2019 Share #2 Posted July 1, 2019 Glad to hear you got the plan going! Now, don't forget to take pics of the trip! Link to comment Share on other sites More sharing options...
luvmy40 Posted July 1, 2019 Share #3 Posted July 1, 2019 If you haven't already, you should slip a length of fuel hose over the steel clutch line to keep it from rubbing on the frame, mounting clamps, etc. Link to comment Share on other sites More sharing options...
RedRider Posted July 1, 2019 Author Share #4 Posted July 1, 2019 If you haven't already, you should slip a length of fuel hose over the steel clutch line to keep it from rubbing on the frame, mounting clamps, etc. We use some vacuum line, but yes. Good idea. RR Link to comment Share on other sites More sharing options...
