rebelbull69sbcglobal.net Posted April 30, 2008 Posted April 30, 2008 i have seen a post on drilling mufflers but thanks to another member on this board {sorry dont remember the name} anatomy of a muffler i have found i cannot do it this certain way with my mufflers. i have the cones and if i took them off i would have the middle pipe sticking out. my question is how is the best way to do this? thanks alot
Marcarl Posted May 11, 2008 Posted May 11, 2008 Don't know how much noise you are looking for, but I just drilled mine out with a 7\8 spade drill bit. From both ends. Gives a bit of a rumble, not anything loud but enough to show that work is being done. Easy to do, all you need is a long extension, the metal is really quite easy to drill out.
FROG MAN Posted May 11, 2008 Posted May 11, 2008 I sawed mine at the weld with a hacksaw and drilled them out. Yea I know one of the holes is not uniform. But hey when I'm cruising nobody notices. The noise is not bad for the rider. I still listen to my am,fm ok.
a1bummer Posted May 13, 2008 Posted May 13, 2008 Check out this post to see what's inside. http://www.venturerider.org/forum/showthread.php?t=3365&highlight=anatomy
