Hey guys! I got the Skydoc clutch upgrade kit and the shift roller upgrade. I need to take the clutch basket out to install the shift roller. Will the bigger housing for the clutch basket just come off after I get the inner basket off?? Also in the manual it says to replace the lock washer, which is this part 90215-25218-00
Here's a picture of the washer its part number 18. Do you guys think I can get away without replacing it??
The basket is held on by a nut. I wouldn't worry about a new washer, but you'll need some special tool to tighten the nut back on. Just sticking a screwdriver in the basket to keep it from turning is not healthy, unless you have another basket handy that needs a home. Don't ask me how I know this, it's top secret!! and yes, I thought I could do better than the instructions. You can make a tool yourself with some wood and nails. You will need to hold the basket from turning the engine isn't going to do that for you.
I was thinking of buying longer bolts for the basket and a 2x4. Figured that would do the trick?
After I massacred my basket I think I just rattled the nut on with an air impact. Did that a few times and haven't heard of a problem yet.
That sounds like a plan
Just buzz her back on
If you dont have a air gun, you can order the Clutch holder as they are available on the aftermarket. The Yamaha part # YM-91042 for the clutch holder. I did a google search and came up with multiple different ones. Motion Pro has one for $25 MSRP. Just letting you know they are out there.
Rick F.
I hold clutch baskets by putting the transmission in the highest gear (5th, in this case) and having a helper apply the rear brake.
Those washers can be safely re-used as long as you're bending fresh metal up against the flat of the nut. When you aren't able to do that then it's time for a new one.
Tim
Tim
Thank you! I appreciate the insight! I dont have it apart yet so ill take a close look at it when i take the basket off!
Even eaaier yet! Thanks!
