B.E. Coyote Posted December 17, 2017 Share #1 Posted December 17, 2017 Bike came to me with a very large hole in the trunk and a few cracks in the bottom. Many articles on how to make repairs to abs plastics using abs pipe cuttings and acetone so I won't go into too many details. The large hole took many coats. I started inside the trunk and used fiberglass cloth to give me something to build up from the outside. When finished, I sanded the entire area of the trunk below the pinstripe with 600 grit paper. I then used a clear primer meant for plastic. Then a normal sandable auto primer, then the color rite paint/clear coat primer. I used a good masking tape on the pinstripe and covered the rest. I have no autobody experience at all so I am pretty happy with the results. After it cures. (5 days) I'll polish it and wax it. Looks great and I added some extra abs to the bottom of the trunk. Probably stronger than new. Link to comment Share on other sites More sharing options...
AJBinVA Posted December 17, 2017 Share #2 Posted December 17, 2017 Looks awesome. If the bike doesn't grow on you you've definitely got some sweat equity come spring time. Link to comment Share on other sites More sharing options...
Marcarl Posted December 17, 2017 Share #3 Posted December 17, 2017 Looks real good from where I'm sitting, had to squint a bit from the glare even. Link to comment Share on other sites More sharing options...
B.E. Coyote Posted December 17, 2017 Author Share #4 Posted December 17, 2017 Thanks, I think the only little niggle is is that there is a slight elevation difference between the pin stripe and the layers of primer, paint and clear coat that I put on. Hoping polish and wax will blend it together. Link to comment Share on other sites More sharing options...
bikenut Posted December 17, 2017 Share #5 Posted December 17, 2017 Great Job Link to comment Share on other sites More sharing options...
Condor Posted December 17, 2017 Share #6 Posted December 17, 2017 Nice Job. I did much the same thing on my '91VR Tuxedo, but the damage was in an area that wasn't really visible, so rattle canned it with Krylon Semi-Flat Black... The holes were there when i bought it, and I'm still trying to figure out how in the 'H' it could have happened... Link to comment Share on other sites More sharing options...
