It was 73 today.Going to be 720-87 next few days.Great riding weather.I also have some electric stuff to try out.How often do you drain antifreeze and what type do you use? Also I read where a guy customized his second gen and the cooling fins are removeable.I would think some sort of bolt holes would be left.I like the fake fins look myself.
FYI those fins hold some rubber stoppers in place that will drain the coolant from the cylinder jackets faster then you can say it, if you're not careful. Those holes would have to be drilled, tapped and plugged to run without the fake fins.
wow.I did not know that.I wasnt going to take them off.But on eleganza berg removed them and had them shaved down a lot.
Those fins are totally fake and their only purpose in life is to hold in the rubber plugs. Otherwise they are strictly cosmetic. So feel free to modify them to your taste. But as mentioned above, they either must be there or some other means must be provided to prevent instant coolant loss when the plugs blow out. Not to mention that that hot coolant will dump right on your legs.
I dont intend removing them, and I for sure have no clue what the holes could be plugged with.I just always want to customize everything.I need to leave things alone.These ventures dont lend themselves to customizing.Mine looks good asis, just never liked the 2 tone silver.But that is a whole different topic.
One thing you could do is have Mike Eykamp, The Diamond Cut Guy, modify a set of fins for you, he has an add here that shows on the top banner or your can go here http://www.thediamondcutguy.com/ he does some nice work.
The triangular pattern of the bolts holding the fins on would adapt easily to the mkV flux capacitor from Fugikowa industries!!
I think you're just fuggin with me
super awesome link.You exchange your core and he sends you the replacements it appears.$400 for fins and dog bones.What are dog bones, are they part of the necessary parts to do the mods? I really like the color combo in the web picture too.I want to do mine like that.
Not my bike. The picture was the work of the diamondcut guy and I am pretty sure he cut the fins after someone had painted them to match the bike
