Aussie Annie Posted March 29, 2017 Posted March 29, 2017 Out on the trike and I get a red light up on the dash, yikes! Not good. Get it to my service guy, and it turned out to be the solenoid. Then head off on the Sunday for my club stone ride, but get to meet point and now it won't start!! My veteran brothers gave me a push start, and I get it home...but it's not pulling too many volts. Now I need a stator !! Alan decides to save a bit of money and do the work himself. Parts ordered and picked up, and he starts the work. All goes well, he decides to check the battery also, in case it has dropped any cells. Well........ last mechanic tightened the negative so bad AL had to break the post off to then get the neg wire off !! Result -- new battery 😳😳😳😳😳😢😢💲💲💲💲💲
Flyinfool Posted March 29, 2017 Posted March 29, 2017 Well if it comes in 3s then you are now good to go..........................
cecdoo Posted March 29, 2017 Posted March 29, 2017 Well Annie, with a new battery, solenoid and stator ya ought to be in pretty good shape on the spark end!
Frogger Posted March 30, 2017 Posted March 30, 2017 Now you should be set to go for a while. Sent from my iPhone using Tapatalk
Dragonslayer Posted March 30, 2017 Posted March 30, 2017 Out on the trike and I get a red light up on the dash, yikes! Not good. Get it to my service guy, and it turned out to be the solenoid. Then head off on the Sunday for my club stone ride, but get to meet point and now it won't start!! My veteran brothers gave me a push start, and I get it home...but it's not pulling too many volts. Now I need a stator !! Alan decides to save a bit of money and do the work himself. Parts ordered and picked up, and he starts the work. All goes well, he decides to check the battery also, in case it has dropped any cells. Well........ last mechanic tightened the negative so bad AL had to break the post off to then get the neg wire off !! Result -- new battery 😳😳😳😳😳😢😢💲💲💲💲💲 Still riding that Hardley?
