Help: Firestik
bikerjohn
Well, I am but mine is the Firstick FM antenna. From what I've read though, even the CB version should work fine. I think you have a wiring issue somewhere. Did you run a cable all the way to the front or cut and splice? I cut and spliced when I did mine but it still worked fine. I'm thinking if you did it that way though, maybe you didn't get the connector right.
Yes, but I can also se what Jack may be saying. If the squelch is set too LOW....it may be putting the CB in receive mode all the time and not allowing the radio to play. Not sure that is what he meant but thinking it may be.
LOL.... Sure that's what I meant... Wink..wink.... :hurts:
