Dragonslayer Posted June 22, 2016 Posted June 22, 2016 Can anyone direct me to a reference for 2nd gen factory paint codes?
djadam Posted June 23, 2016 Posted June 23, 2016 I have a question hopefully someone can help with. I have the 06 RSV, color is Black Cherry, which is the best color by the way!! On the colorrite website, the only color that looks close is called very dark red. I thought there was a year that the RSV had dark red and black maybe? Anyway, does anyone know if that is the Black Cherry color, and if it's not, do you know where to get it? I need to do a little touching up. Thanks for any help
videoarizona Posted June 23, 2016 Posted June 23, 2016 I have a question hopefully someone can help with. I have the 06 RSV, color is Black Cherry, which is the best color by the way!! On the colorrite website, the only color that looks close is called very dark red. I thought there was a year that the RSV had dark red and black maybe? Anyway, does anyone know if that is the Black Cherry color, and if it's not, do you know where to get it? I need to do a little touching up. Thanks for any help Isn't this it? >> Motorcycle :: 2006 :: Yamaha :: Royal Star Venture (All Models) Click on a part number below to select a product to see available options. IMPORTANT NOTE: Some colors require a base color to create a special color effect. This is called a "TriCoat" which is Base + Top + Clearcoat. If your color is a TriCoat, the base color will be listed below under "ColorRite Base" and you will need to order both the Top and Base listed. We always recommend clearcoat for the proper match and maximum protection. [TABLE=class: color, width: 590] [TR] [TD=align: center]Code[/TD] [TD=width: 200, align: center] Paint Name [/TD] [TD=width: 200, align: center]Comment[/TD] [TD=width: 50, align: center]Color Chip[/TD] [TD=width: 70, align: center]ColorRite Top[/TD] [TD=width: 70, align: center]ColorRite Base[/TD] [/TR] [TR] [TD=align: center]0957 [/TD] [TD]Very Dark Red Metallic #2 (VDRM2) [/TD] [TD]Regular Venture Color [/TD] [TD=bgcolor: #660000] [/TD] [TD=align: center] 5200 [/TD] [TD=align: center] [/TD] [/TR] [TR] [TD=align: center]0903 [/TD] [TD]Black Metallic X (SMX) [/TD] [TD]Midnight Venture Color [/TD] [TD=bgcolor: #000000] [/TD] [TD=align: center] 5245 [/TD] [TD=align: center] [/TD] [/TR] [TR] [TD=align: center]0033 [/TD] [TD]Yamaha Black (YB) [/TD] [TD]Frame/Wheel Color [/TD] [TD=bgcolor: #000000] [/TD] [TD=align: center] 5135 [/TD] [TD=align: center] [/TD] [/TR] [TR] [TD=align: center]0582 [/TD] [TD]Mat Black Metallic #2 (MBL2) [/TD] [TD]Engine Color [/TD] [TD=bgcolor: #000000] [/TD] [TD=align: center] 5988-1 [/TD] [TD=align: center] [/TD] [/TR] [/TABLE] Color swatch is just an approximation for reference. It is not an exact color representation.
videoarizona Posted June 23, 2016 Posted June 23, 2016 http://www.colorrite.com/product/yamaha-0957-very-dark-red-metallic-2-vdrm2-1770.cfm
