videoarizona Posted August 3, 2015 Posted August 3, 2015 Looking to buy two front rotors as mine appear to be warped. At Pinwall...I noticed they have rotors from two models: XVZ1300 & XVZ13TF The rotors look the same...but out of curiosity, what is the difference between the two? Thanks, david
etcswjoe Posted August 3, 2015 Posted August 3, 2015 XVZ1300 Tour Deluxe XVZ13TF RSV Rotors are the same.
billmac Posted August 10, 2015 Posted August 10, 2015 can RSV and RSTD rotors be used on either bike.
etcswjoe Posted August 10, 2015 Posted August 10, 2015 can RSV and RSTD rotors be used on either bike. I looked up both bikes part's list and it was the same part number.
RSTDdog Posted August 15, 2015 Posted August 15, 2015 Warping rotors should not be common issue unless you have put alot of miles/wear on them or use aggressive pad compounds. Be sure you don't have a sticking caliper or you may warp another set. Check that shaking on brake application is not related to loose steering head bearings. If you haven't flushed changed brake fluid and cleaned out the master cylinder and brake components, now would be a good time. Rtsd/Venture rotors are fully interchangeable. The floating Rotors from the Stratoliner/Roadliner (as well as the front wheel assembly from those bikes) will also work. ddog
videoarizona Posted August 15, 2015 Author Posted August 15, 2015 DDog...problem was a warped rotor. Probably got damaged when I took front wheel in to shop for new front tire. My bad for not taking the rotors off! I checked the calipers, brake fluid was changed, etc.. I did everything else first as I've never had a rotor warp on a scoot before. Used rotor from Pinwall came in...problem solved. Now curious if I can unwarp my old rotor!!
RSTDdog Posted August 15, 2015 Posted August 15, 2015 Thats too bad. A shop that knows what they are doing should be able to swap the tire with out damaging the rotor. Its their bad, not yours- They are the professionals, They owe you a rotor IMO. Its not that much slower to just spoon the tire off with irons. Guys that are good with irons are faster than a tire machine. Becoming a lost art like truing spoked wheels. Not sure if trying to straighten it would be worth it.
seabeetom Posted August 23, 2015 Posted August 23, 2015 XVZ1300 Tour Deluxe XVZ13TF RSV Rotors are the same. Yo Joe! What be the difference between a XVZ13TFL and a XVZ13 TFLC? ditdahditdahditdah!
etcswjoe Posted August 23, 2015 Posted August 23, 2015 Yo Joe! What be the difference between a XVZ13TFL and a XVZ13 TFLC? ditdahditdahditdah! "C" is California model, more emissions crap. http://morse-code.eu/m/eJxjZJCTYwjJSFVQclZSyCxWSMsvUigBcp0TczKB7LzMRIXc_JTUHAUA2rEMMw==
seabeetom Posted August 25, 2015 Posted August 25, 2015 Thanks for the answer Shipmate. I C U caught the Morse Code reference... Must be a Navy thing.
