MileHi Posted June 21, 2015 Posted June 21, 2015 after going through that very usefull step-by-step test of the RR and Stator here's what i got: RR diodes all test good. Winding resistance good and equal on all three winding voltage good on all three (27vac at idle and up to 75 when i rev it, dep on how high i rev. as long as i hold the throttle steady the voltage stays pretty stable.) when i plug it all back together and reconnect battery ground and start it i get 13.9vdc initially, but it fluctuates wildly downward even to below battery charge voltage. when i check ac voltage across the windings with the RR plugged in i, of course get a lower ac voltage but it's stable. (about 10vac) My thinking is that it's a bad RR with good diodes. Does that sound right to you guys? btw this is my first day on the forum and there's a ton of useful info here thanks, MileHi
etcswjoe Posted June 21, 2015 Posted June 21, 2015 Make sure your R/R connector is not burnt up and is very clean also check the stator connector under the battery box. After all of those are cleaned up recheck.
Flyinfool Posted June 21, 2015 Posted June 21, 2015 Hmmmmm First off welcome to the nut house. Did you have the battery load tested? With a fully charged battery, what is the battery voltage with the bike running. First thought is bad RR, But the comment you made about the stator voltage dropping so far while running sounds more like a bad battery or something on the bike pulling a high amp draw, like a pinched wire or defective accessory.
MileHi Posted June 22, 2015 Author Posted June 22, 2015 When I get home I'll recheck the connectors and start checking for shorts fuse by fuse. I started the stator/rr checks with the battery charged to 12.8vdc
tj3777 Posted June 22, 2015 Posted June 22, 2015 Windings can initially check normal when cold. But when under a "load" the varnish coatings may break down and short out. The same with any electrical device - including when new......
MileHi Posted July 2, 2015 Author Posted July 2, 2015 Turned out to be a while before I could get back to it. It was the RR. Right now I'm running on one from an 04 vstar and want to order a reliable replacement. Any suggestions on brand and source? (Took her for a test ride Sunday and got back 3 hours later and used up the good part of a tank of gas. I've owned a wing and two ventures. This is the sweetest ride I've ever been on)
