jonesy Posted January 7, 2007 Posted January 7, 2007 Can anyone help with cause, oil leaking from valve cover area, very low mileage bike. Out of warranty.
Eck Posted January 7, 2007 Posted January 7, 2007 IF>>>>> IF>>>> IF>>> if the leak if coming from between the valve cover and the head, you must replace the valve cover gasket.. No other choice..except one thing you can try... Check to see if the VALVE COVER hardware is tight... if not, tighten it per spec and see if leak is still there... IF it is......valve cover gasket replacement time..... My guess is the valve cover hardware is not tight.....and retightening it just MAY work... try it and see..
