I'm just wondering if I should be thinking about a replacement?
The engine guard on that side seems to have a tab that rests inside this dent perfectly.
While you have the guard off, grind about a 1/4 inch off to give you more clearance and remove the sharp edge where it is near the elbow. Also, if it is bent from the bike being dropped, you will need to pry the guard away from the engine some more. I think those elbows new now are about $50. Another one of those "fifty cents to make" parts that are outrageously priced.
RandyA
That is a real common dent. Guaranteed to start leaking coolant at some point. Might as well replace it now, and do Randys mods to the guard, AND stop dropping it on that side.....
Put your foot on the guard and bend it back out to where it's supposed to be. If you want to replace the tube for cosmetics reasons, go ahead, but if it doesn't leak and you don't mind the blem.... ride it...
