Yamamike Posted September 24, 2014 Posted September 24, 2014 I know the subject of tires has been discussed at length but I will require a new front before next season and I'm wondering if there are any do's and don'ts as far as mixing brands. I currently run Kenda Kruz front and rear and the reason for replacing the front is cupping. I'm not sure if the cause was balancing or pressure but I will certainly be monitoring the new tire very closely and getting the new one balanced properly. Any suggestions?
Big Auggie Posted September 24, 2014 Posted September 24, 2014 I've heard only good things about the product Ride On. It balances the tire and seals punctures. Google it to read the specifics. A friend had it in his tires and it had several puncture wounds by the time he put new tires on.
videoarizona Posted September 24, 2014 Posted September 24, 2014 I found cupping on my rear tire...cause was the air pressure was set by P.O. at yamaha specs. I increased air pressure to almost the max the tires say for max load....the problem seems to be going away. Will see if the rear end whine goes away as well. Cupping wear seems to cause that sometimes...
kevin-vic-b.c. Posted September 24, 2014 Posted September 24, 2014 I do not know your tire brand at all but I know the cupping on my brothers BMW with Metzler tires was totally pressure related. You need to read the tire to find out manufactures recommended pressures then you can play a few PSI from there. Example is my Avon front is rated for 42 PSI max full load. 42 is high so I started at 40 and that was firm, dropped to 38 and it felt good, dropped to 36 is it was mushy feeling. I run 38 PSI front now. My V-Strom I run lower front tire pressure for the feel and flexibility, I don't have to change pressures for gravel road riding.... I can see the cupping starting
Condor Posted September 24, 2014 Posted September 24, 2014 The only reason a tire will cup is due to sidewall flex caused by low tire pressure....
