mpoertner Posted August 4, 2014 Share #1 Posted August 4, 2014 Does anyone have a digital copy of the owners manual? That might answer a lot of my questions about this bike. But if anyone has feedback on the following concerns I’d appreciate it. There is a rocker switch with a green lens. It doesn’t light up on or off. What does it do? Left turn signal does not work unless I first engage the right. Brake fluid reservoir warning is lit. But all reservoirs are full. I see in the specs a Compression Ratio but what is the Pressure spec? Kickstand bolt broke. Can’t find one with a shoulder at the local hardware stores. Any idea for a replacement? Thanks! Link to comment Share on other sites More sharing options...
Prairiehammer Posted August 4, 2014 Share #2 Posted August 4, 2014 Does anyone have a digital copy of the owners manual? That might answer a lot of my questions about this bike. But if anyone has feedback on the following concerns I’d appreciate it. There is a rocker switch with a green lens. It doesn’t light up on or off. What does it do? Left turn signal does not work unless I first engage the right. Brake fluid reservoir warning is lit. But all reservoirs are full. I see in the specs a Compression Ratio but what is the Pressure spec? Kickstand bolt broke. Can’t find one with a shoulder at the local hardware stores. Any idea for a replacement? Thanks! Does anyone have a digital copy of the owners manual? That might answer a lot of my questions about this bike. But if anyone has feedback on the following concerns I’d appreciate it. There is a pdf of a 1984 XVZ12L/DL here. The 1983 is basically the same except for the addition of cruise control on the XVZ12DL. The 1984 instrument panel is different from the 1983, too. There is a rocker switch with a green lens. It doesn’t light up on or off. What does it do? That switch is not OEM. Probably added by a PO for switching lighting or perhaps as a manual cooling fan control. Trace the wires to confirm it's function. The switch may be functioning, but the pilot light on the switch may be burned out or the switch wiring is incorrect to light the pilot light. Brake fluid reservoir warning is lit. But all reservoirs are full. If you are SURE the reservoirs are full, (Be very careful when checking the rear brake reservoir, for the reservoir fill plug boss is easily broken off the reservoir. It is best to use a properly fitted wrench to the fill plug boss and 'hold back' on this boss while simultaneously removing the fill plug.), then the switch float is probably hung up in one of the reservoirs. One cannot remove the rear brake reservoir cap (no to be confused with the reservoir fill plug) while the reservoir is on the bike. But one must remove the reservoir cap to check the fluid float switch operation. Kickstand bolt broke. Can’t find one with a shoulder at the local hardware stores. Any idea for a replacement? The kickstand bolt is available from your Yamaha dealer or any of the online vendors, such as Boats.net. http://www.boats.net/parts/detail/yamaha/Y-90109-10474-00.html You may also bore out the hole and insert a hardened grade 8 bolt as is done with the "Dingy Mod". http://www.venturerider.org/forum/showthread.php?threadid=48342 Link to comment Share on other sites More sharing options...
Venturous Randy Posted August 4, 2014 Share #3 Posted August 4, 2014 A note to add to Prairiehammers' great response concerning the brakes is be very careful that you do not get any brake fluid on the plastic. Also, do not fill the reservoirs to the top as it will cause the brakes to lock up when the fluid gets warm. Always carry an 8mm wrench with you so you can relieve some fluid pressure if you need to. Unless the brakes have been modified, the left front caliper and the rear brake are linked together. RandyA Link to comment Share on other sites More sharing options...
mpoertner Posted August 4, 2014 Author Share #4 Posted August 4, 2014 Thanks!!! Lots of great info there. You sure saved me a lot of time searching. I really appreciate that!. Link to comment Share on other sites More sharing options...
dna9656 Posted August 6, 2014 Share #5 Posted August 6, 2014 Does anyone have a digital copy of the owners manual? That might answer a lot of my questions about this bike. But if anyone has feedback on the following concerns I’d appreciate it. There is a rocker switch with a green lens. It doesn’t light up on or off. What does it do? Left turn signal does not work unless I first engage the right. Brake fluid reservoir warning is lit. But all reservoirs are full. I see in the specs a Compression Ratio but what is the Pressure spec? Kickstand bolt broke. Can’t find one with a shoulder at the local hardware stores. Any idea for a replacement? Thanks! The best one I have seen is on ebay it's called "Tech Spark' and includes generic how to on bikes too as well as some games! Link to comment Share on other sites More sharing options...
comingbackdown Posted August 6, 2014 Share #6 Posted August 6, 2014 or perhaps as a manual cooling fan control Quite possible. I've got one on my '83. I'd love to slap the PO for how he installed it (and I know the guy, too) but I digress. One warning though, if that's the case, don't ignore your temp gauge. Link to comment Share on other sites More sharing options...
srknova74 Posted August 6, 2014 Share #7 Posted August 6, 2014 My turn signal switch did that on my 84. Dissembled and cleaned with lectramotive electronic parts cleaner. Works great now. Link to comment Share on other sites More sharing options...
Condor Posted August 6, 2014 Share #8 Posted August 6, 2014 On the brake light. Make sure you reserves are only filled to the middle of the sight glass. This holds true for the left hand clutch as well. On the brake light, there is a baffle in the top of the rear reserve that will sometimes get extended down into the reserve holding the float under the surface, and it needs to be collapsed again. The only access is through the fill hole, unless you want to take the thing off, and it's best to leave well enough alone... Take a short piece of coat hanger with a 1/2" 'L' and you can reach inside and pull up to partially get the baffle collapsed enough to allow the float to .... Float... instead of being held down and triggering the light. Link to comment Share on other sites More sharing options...
BobfromSWOhio Posted August 14, 2014 Share #9 Posted August 14, 2014 Have converted 83 venture royale to trike and and maybe able to find bolt if not sourced locally. BobfromSWOhio Link to comment Share on other sites More sharing options...
miff Posted August 29, 2014 Share #10 Posted August 29, 2014 Have converted 83 venture royale to trike and and maybe able to find bolt if not sourced locally. BobfromSWOhio Do You have any pics of your trike? I have an '83 trike also. Link to comment Share on other sites More sharing options...
