Big Dog Posted June 9, 2014 Share #1 Posted June 9, 2014 I have an 07 RSV and when I push the starter button it starts to turn over then a loud snap and it stops and when i push it again just a click I thought it might be the battery so I charged it overnight and the same I took the battery nto be load tested and its good so is it the starter or something else? Link to comment Share on other sites More sharing options...
bongobobny Posted June 9, 2014 Share #2 Posted June 9, 2014 May be the solenoid. With the key on short out the 2 big wires and see if it tries to start. If it does then the solenoid (located along the battery box) is shotski. Link to comment Share on other sites More sharing options...
rougeray Posted June 9, 2014 Share #3 Posted June 9, 2014 Is it possible you have a hydraulic lock from liquid gasoline in the cylinder? One test is to remove spark plugs and try turning it over. Link to comment Share on other sites More sharing options...
Neil86 Posted June 9, 2014 Share #4 Posted June 9, 2014 or crank it over with socket on rotor. Link to comment Share on other sites More sharing options...
RSTDdog Posted June 11, 2014 Share #5 Posted June 11, 2014 Is it possible you have a hydraulic lock from liquid gasoline in the cylinder? One test is to remove spark plugs and try turning it over. Hopefully its not this ^^, but you should check this out.Stuck float can fill cylinder with gas. Is oil overfull? Remove plugs and do this test before doing bongobobny's test. If it is hydrolocked, the extra current from jumping the solenoid may get you a bent a rod. How many miles? Bike been sitting? Link to comment Share on other sites More sharing options...
V7Goose Posted June 11, 2014 Share #6 Posted June 11, 2014 Sounds like a bad electrical connection to me - start with the main engine ground just above the clutch cover. If that is good, focus on the battery connections and the starter connections. Take the cables off the battery and SCRAPE them with a knife - often they can develop a hard CLEAR coating much like glass that is an insulator. Goose Link to comment Share on other sites More sharing options...
Big Dog Posted June 18, 2014 Author Share #7 Posted June 18, 2014 It was the battery cables they look good just a little copper tarnish so I used a steel bruxh and contact cleaner and it fired right up. Thanks for the help. Link to comment Share on other sites More sharing options...
