Razorback Posted May 31, 2014 Posted May 31, 2014 http://img.tapatalk.com/d/14/05/31/ga4abyby.jpg I have no idea where it goes and as far as I know it's never been hooked up. If it should be, I don't know when the other end of it is. It contains a red and a black. My bike is a standard Venture. Sent from my iPhone using Tapatalk
Razorback Posted May 31, 2014 Author Posted May 31, 2014 And this one under the instrument cluster, has a Red/blue, a Red/brown? And a blackhttp://img.tapatalk.com/d/14/05/31/a5ymuga9.jpg Sent from my iPhone using Tapatalk
MiCarl Posted May 31, 2014 Posted May 31, 2014 IIRC the first one just hangs there to make you wonder if something is disconnected........ Other might be the connector to the turn signal.
Flyinfool Posted May 31, 2014 Posted May 31, 2014 The first one would go to a condenser o filter alternator noise in the sound system. the second one is power, memory backup and ground connection to power the factory radio. Neither of these are used on a standard but would be used on a royal. That is my best guess anyhow.
Razorback Posted May 31, 2014 Author Posted May 31, 2014 The first one would go to a condenser o filter alternator noise in the sound system. the second one is power, memory backup and ground connection to power the factory radio. Neither of these are used on a standard but would be used on a royal. That is my best guess anyhow. Kinda what I figured, which is why i specifically mentioned mine was a Standard. Now back to putting it back together. BTW, you guys know how hard it can be to just buy a little bulk 7mm spark plug wire in a smallish town? No one has it.
djh3 Posted May 31, 2014 Posted May 31, 2014 I have some solid core copper accell stuff in the garage.
KIC Posted May 31, 2014 Posted May 31, 2014 I went all over town looking for bulk plug wire. Even places that said they had it (online) didn't have it in the store. I finally bough a decent set for an 8 cylinder and cut them to length . I still have four new ones left over from that.
