djh3 Posted October 22, 2013 Share #26 Posted October 22, 2013 Well I ordered some parts for a winter project on this subject. I ordered a mic for a lap top that plugs into a 3.5mm jack and I ordered a 5 pin connector. I'll try to remember to take some pics and post when I get it done or as I go along. Let you all know how it works if it does. LOL Link to comment Share on other sites More sharing options...
djh3 Posted November 21, 2013 Share #27 Posted November 21, 2013 (edited) Parts arrived/ 5 pin connector and the PC mic. I ordered on like this. http://thumbs3.ebaystatic.com/d/l180/pict/121102298146_1.jpgUsing the drawing I have for the 5 pin hook up I just pished in wires to the pins on the bike side and couldnt get anything. Is the mic plug the same as the earphone plug in the diagrham? Closest to plug is common (mic shield) then should be able to just connect the 2 other bands together in plug in rite? I am pretty sure I had the IC on, volume up but could hear nothing over the ear buds I had plugged in. 11/21/13 4pm Just confirmed the IC was up and I was on headset mode. I even thought possibility of maybe bad mic even though it is new. So I had another PC mic around and tried it. Same results Naada. Edited November 21, 2013 by djh3 Link to comment Share on other sites More sharing options...
Bob Myers Posted November 22, 2013 Share #28 Posted November 22, 2013 Is this the one you used? This is how mine are wired Link to comment Share on other sites More sharing options...
djh3 Posted November 27, 2013 Share #29 Posted November 27, 2013 Bob I think that one jives with the diagrham I posted. Still naada. No click nothing. Sort of stumped. Link to comment Share on other sites More sharing options...
Bob Myers Posted November 28, 2013 Share #30 Posted November 28, 2013 Have you actually heard anything through any headset on this bike? Link to comment Share on other sites More sharing options...
djh3 Posted December 1, 2013 Share #31 Posted December 1, 2013 Yes headsets work fine. Matter of fact I added a cable from up front under the faring that I run a 3.5mm for ear buds back to normal headset connection. Everything works great. Just trying to figure out this mic deal. I may be barking up the wrong tree or something here trying to make something. Link to comment Share on other sites More sharing options...
Bob Myers Posted December 1, 2013 Share #32 Posted December 1, 2013 Yes headsets work fine. Matter of fact I added a cable from up front under the faring that I run a 3.5mm for ear buds back to normal headset connection. Everything works great. Just trying to figure out this mic deal. I may be barking up the wrong tree or something here trying to make something. Is the mic you want to use a dynamic or condenser(electret) mic? Link to comment Share on other sites More sharing options...
djh3 Posted December 2, 2013 Share #33 Posted December 2, 2013 (edited) I dunno I thought it was the kind discribed earlier in this post. It is shown in one of post. It plugs into a 3.5mm plug, orginaly it goes to a lap top. Bob here is the listing for the mic. Edited December 2, 2013 by djh3 Link to comment Share on other sites More sharing options...
Bob Myers Posted December 3, 2013 Share #34 Posted December 3, 2013 If all that is, is a mic then I'd about believe it is an electret mic, no other reason I could see for them to use a 3 ring terminal when a dynamic mic only needs 2. Link to comment Share on other sites More sharing options...
djh3 Posted December 3, 2013 Share #35 Posted December 3, 2013 I dont know I thought maybe for stero lt and rt channel or something. I dont know what else to try on the fly. I didnt think those PC mics were powered either. Link to comment Share on other sites More sharing options...
Mad Dog Posted March 2, 2014 Share #36 Posted March 2, 2014 So, at the risk of opening up a dead thread... I'm wondering how this all worked out ... not that I understood a lot of it! From what I did grasp you are trying to use regular mini plug earbuds or speaker(s) and another mini plug to a microphone and put these two mini plugs through an adapter that connects it into the standard sound / intercom system so there are affordable options...?? Is that correct? If so, thats what I'm looking for info on! Did anyone ever get this to work and produce a How-to? I might be willing to donate to the cause if that would help move this along. I'm not understanding any of the technical stuff, but I am hoping to get some guidance. Thanks Link to comment Share on other sites More sharing options...
dacheedah Posted March 2, 2014 Share #37 Posted March 2, 2014 http://www.goldwingfacts.com/DIYintercom.htm Link to comment Share on other sites More sharing options...
Mad Dog Posted March 2, 2014 Share #38 Posted March 2, 2014 http://www.goldwingfacts.com/DIYintercom.htm Thanks! Don't understand it yet, but good to see! Appreciate it. Link to comment Share on other sites More sharing options...
Bob Myers Posted March 2, 2014 Share #39 Posted March 2, 2014 I made the wife a single side headset adapter to use in our sidecar, with no helmet. She does not like to hear music so i wired this to capture the right channel only, when intercom is active it feeds both channels equally so I can have my music on the left and intercom on both, she only gets intercom. Over complicated but it works Any way I used a standard 5 pin Din connector and wired a stereo type plug to it, capturing only the right output/ground, and mic input/ground. She uses a single side headset, I wear a helmet with standard setup. If you use a standard stereo headset you would wire the left also. pic below is of the headset Link to comment Share on other sites More sharing options...
