Behind the back cylinders is mounted a small cylinder shaped object with a 2 wire connector, I believe its called a condenser. I looked on the 89 I have and it doesn't have one. Does anyone know what this thing does? It looks like this ebay item.
http://www.ebay.com/itm/86-YAMAHA-XVZ13-XVZ1300-VENTURE-ELECTRICAL-COMPONENT-38-/330967048723?pt=Motorcycles_Parts_Accessories&hash=item4d0f2c6213&vxp=mtr
1NL-81965-01-00 CONDENSER, SMOOTHING
It's in the Audio 1 fiche.
My guess is it was part of power supply noise reduction for the audio system. It was not used in 89 but turned back up in the 2nd gen.:think:
The schematics that I posted are wrong as far as this part is concerned. I showed it on the 86-93 1st gens. The parts fiche only shows it in 86 & 87 though as Micarl stated.
Gary
If you've got any audio system you may need a noise filter on the power supply. Won't hurt anything to try without.
If you have noise you can buy something at the car audio shop for a fraction of the Yamaha price, and it'll probably work better too.
  frankd said:
No, without an audio system, you have absolutely no need for it.
I have an after market Pioneer head unit. I did try it and didn't get any noise.
  • 3 weeks later...
Gary
Should there be 12v on it with the key off? Because there is on mine.:shock3:
Per the schematics there would be power on it constantly.
A condenser (capacitor) will not pass DC current through. So there should be no drain on the battery.
Gary
