darthandy Posted August 8, 2013 Posted August 8, 2013 I plan on putting some anti-squeal spray on my pads (Just the back of course!). In theory, since the outboard pad has a shim, it shouldn't need any. Should I spray it as well anyway? And if so, do I spray the pad first or after the shim is installed? I searched the forum and found that someone had once asked he same question but never received an answer. I am curious to know. Thanks Andy
djh3 Posted August 8, 2013 Posted August 8, 2013 I think the "shim" your talking about is a thin metal spring sort of piece. Its probably designed to take the rattle or vibration out of the pad/caliper when applying brakes. Simular to an anti-rattle spring on a car. TRW and a few others make some spray on stuff. Lay the pad contact face down on cardboard or something and spray the back, 2 or so light coats is better than trying to goop it on in one. I would do both pads.
darthandy Posted August 8, 2013 Author Posted August 8, 2013 Yes, you're right about the shim. It is supposed to eliminate the squeal but I've seen (heard?) brakes squeal even with these attached. That's why I was wondering if I should spray both pads. However, since the "shim" rides against the pistons, I wondered if I should spray the back of the shim as well. Andy
Marcarl Posted August 8, 2013 Posted August 8, 2013 Just file a small 45 degree angle on the leading edge of the pads,,, problem solved!
CaptainJoe Posted August 8, 2013 Posted August 8, 2013 (edited) Or just buy HH sintered brake pads. The harder OEM pads will glaze your rotors. I know they glazed mine... Edited August 9, 2013 by CaptainJoe
Globewalker Posted August 8, 2013 Posted August 8, 2013 i have tried the anti squeal stuff (dont recall if I also applied on the shim) but still have the squeal may need to try the 45 degree angle trick
darthandy Posted August 9, 2013 Author Posted August 9, 2013 Well, I had already bought the EBC HH pads and I put a bit of a bevel on the pads (I'm not really good at doing that so I didn't want to overdo it.). And then, I put the anti-squeal spray on the backs of each pad and the shim. If the brakes squeal now (Which they did badly before I put some anti-squeal on the old ones) then I'll resort to turning up the volume on the radio! Thanks everyone for the ideas and advice. Oh yeah ... I gave the calipers as good a cleaning as I could with some Q-tips, cleaner and a toothbrush. Now we'll see. Just have to flush and bleed the system tomorrow. Andy
dacheedah Posted August 9, 2013 Posted August 9, 2013 Clean the pin very well and a lite coat of antiseize on it. That will let the pads move smooth. Sent from my iPhone using Tapatalk
