dave_wells Posted April 3, 2013 Posted April 3, 2013 I just purchased a 2000 venture I could use a mount and wire setup for the zumo 550 Currently I have a 550 on my rstd all I want to do is be able to swap the GPS from one to the other as needed Thought I would ask here before looking elsewhere Anyone have one or point me in a good direction eBay is next Thanks all
KeithR Posted April 3, 2013 Posted April 3, 2013 Did you try on www.zumoforums.com ? You need to sign up to post tho. Keith
TDbiker Posted April 3, 2013 Posted April 3, 2013 Here is a source I found: http://www.mountguys.com/ Good luck, Glenn
Condor Posted April 3, 2013 Posted April 3, 2013 I think the Zumo and the Street Pilot have the same type ball mount. I put together a set up using the RAM articulating short arm, and a stainless steel clamp sold by an eBayer. Originally I used the RAM ball mount that RAM stated fit the SP550, but found they don't know what the 'H' they're talking about. So I went back to the eBay seller and found out that he also makes the ball to fit the 550. Couldn't be happier. The attached pic shows the clamp/arm/ and RAM ball. One of these days I'll take a pic of the mount with the 550 ball.
bongobobny Posted April 3, 2013 Posted April 3, 2013 I might, I'll check later. If I still have it it's yours! I bought a new Zumo last summer...
