Hi just a quick question about 2ND gen . the coolant plugs on the side of the block how hard are they to change . I have 2 leaking . I know how to take out but is there a trick to put them back in . this is going to be my tomorrow job . then finish putting everything back together then bike is ready to go .:thumbsup2:
Make sure you drain the coolant 1st or you will have a hell of a time tring to put them back in with anti freeze going all over the place
:whistling:
Thank you Steve and Don for your answers . That is going to be my job first thing in morning and then change anti-freeze and then finish putting bike back together than it is riding time . :big-grin-emoticon:
:whistling:
I thought that's the way to drain it :confused24:
Barry, someone posted a tip about cutting the bottom out of a plastic water bottle to catch the coolant that drips out when you pull the plugs. Worked pretty good for me.
Several members have glued a dime on the cover to put more presure on the plug, rather than replace them, with good success...
Yeah I did the dime trick and glued it on the inside of the cover
with no leaks. The Yamaha dealer did not have any of the plugs. I did order the new plugs so I have them if I ever need them. I did this about 10,000 miles ago. This is real easy to do.
Hal :080402gudl_prv:
Thank you I will do that .
Barry
When I ordered the plugs at the yamaha dealership Which I had to give them the parts # they said they never seen them or heard of them . I hate going to them . But I needed the plugs .
Barry
:scratchchin:
:whistling:
Actually, I do not find this necessary at all. I have changed the plugs and lost no more than about a thimble-full of coolant. Just screw an old spark plug in the existing plug and quickly put your thumb over the hole as you pull it out. Then grab the new plug and just pop it in as soon as you pull your thumb away. Much quicker to do than to write about it.
But if you haven't changed your coolant in the past five years, then this is the ideal time to do that too. Good luck,
Goose
Barry
:scratchchin:
Which dealer? I've always had good service at Bob's in Chatham.
Gary that is the dealer that my bike came from . I drop in there when ever I am in Chatham they are good . It was in Windsor that I was Talking about .
Barry:confused07:
Who has the franchise in Windsor now? I thought Iggy "Power Cycle" gave it up. I never liked dealing there and now it's worse then ever trying to find a parking spot since they moved the street over. I only ever went there for tire changes but now I go to a place in Belle River with lots of parking.
BTW, I saw a few bikes out and about today around the county. Still too much salt residue on the roads to suit me though.
Yes it is still Iggy that runs the place but his son is around there to . You might as well talk to the wall when going in there Iggy forgets everything you want and he has to order everything in . I finally got the bike 99% back together today I have to figure out how to get into where the fuel filter is and change it . But it will be done this week :big-grin-emoticon:
