bmccck Posted March 8, 2013 Share #1 Posted March 8, 2013 Hello again! Spring can't come soon enough! About those antenna on the RSV . . . are they permanent fixtures or can they easily be removed and stored when I will not want to use them . . . like when I am riding around locally? Would appreciate knowing more about those things! Thanks!! Link to comment Share on other sites More sharing options...
RedRider Posted March 8, 2013 Share #2 Posted March 8, 2013 You can remove them, but they are not intended to be removed. The mounts would still be in place, the cable would need to be tied up. Your radio nor CB would work. You risk breaking some items that are not cheap to fix/replace. My suggestion is to leave them alone. RR Link to comment Share on other sites More sharing options...
Carbon_One Posted March 8, 2013 Share #3 Posted March 8, 2013 They can also be folded if you need to use a bike cover or need the height reduced. Larry Link to comment Share on other sites More sharing options...
etcswjoe Posted March 8, 2013 Share #4 Posted March 8, 2013 You can replace them with aftermarkets that are shorter too if you desire. Link to comment Share on other sites More sharing options...
ScottW Posted March 8, 2013 Share #5 Posted March 8, 2013 Any idea of a cheap aftermarket that fits? Link to comment Share on other sites More sharing options...
