CaptainJoe Posted August 15, 2012 #1 Posted August 15, 2012 I have a 07 RSV with a stock stator. Need to install something that will draw 5V/.5A/2.5W? Is it possible to do this with the stock stator or will I have to upgrade. Thinking the stock stator won't handle it, so, need one that will. Any suggestions?
Freebird Posted August 15, 2012 #2 Posted August 15, 2012 It is impossible to answer that question without knowing what other accessories you are running. If that is all, then it should be no problem at all.
CaptainJoe Posted August 15, 2012 Author #3 Posted August 15, 2012 (edited) Thanks Freebird, Not running any other accessories, except for the two LED tailights on the cooler rack and the LED light bar on my spoiler. Oh... and a stebel horn... everything else stock, no electric hogs like driving lights or heated grips or heated clothing... Was researching an article V7Goose wrote a while back and concluded that since I'm not running driving lights, heated grips(which would put one right on the edge), adding something with this little draw should be no problem at all? http://www.venturerider.org/forum/showthread.php?t=5042&highlight=voltage+guage Edited August 15, 2012 by CaptainJoe
Freebird Posted August 15, 2012 #4 Posted August 15, 2012 I agree. I wouldn't be concerned at all. You should be good to go.
dingy Posted August 15, 2012 #5 Posted August 15, 2012 captainjoe said: I have a 07 RSV with a stock stator. Need to install something that will draw 5V/.5A/2.5W? Is it possible to do this with the stock stator or will I have to upgrade. Thinking the stock stator won't handle it, so, need one that will. Any suggestions? 2.5 watts is a very minimal power draw addition. I would think it would most likely be a safe addition. Gary
CaptainJoe Posted August 15, 2012 Author #6 Posted August 15, 2012 Thanks Guys, experiment continues and everythings going as expected.
Ozlander Posted August 16, 2012 #7 Posted August 16, 2012 dingy said: 2.5 watts is a very minimal power draw addition. I would think it would most likely be a safe addition. Gary Yeah, but that is at 5 v. At 12 v it's going to be about three times as much for a short period of time.
Guest tx2sturgis Posted August 16, 2012 #8 Posted August 16, 2012 Your stock electrical system wont even know its there. Since the stock system will handle about 100 watts extra load, youre way under that.
Freebird Posted August 16, 2012 #9 Posted August 16, 2012 Ozlander said: Yeah, but that is at 5 v. At 12 v it's going to be about three times as much for a short period of time. You are actually backwards on that. I am assuming that he will have to use some type of voltage reducer to get it down to the needed 5 volts. If it did indeed run on 12 volts though, the amps/watts could actually be less, not three times more.
Guest tx2sturgis Posted August 16, 2012 #10 Posted August 16, 2012 It sounds like he is going to be hooking up either a cell phone charger, a GPS, or a satellite radio. Most of these run on 5 volts, but use a voltage reducing DC-DC adapter that runs on 12 volts( 13.6 actually). Assuming the adapter is 50% efficient, the 2.5 watt required by the unit might cause a 5 watt total load on the bike. Still not enough to even be a concern. Of course, if you added 20 of these, then it WOULD be a concern.. Or if the bike was at or near its max (70w passing lights, 50 watts trailer lights, 35w heated vest etc) then the extra 5 watt load COULD be a deal breaker.
twigg Posted August 16, 2012 #11 Posted August 16, 2012 tx2sturgis said: It sounds like he is going to be hooking up either a cell phone charger, a GPS, or a satellite radio. Most of these run on 5 volts, but use a voltage reducing DC-DC adapter that runs on 12 volts( 13.6 actually). Assuming the adapter is 50% efficient, the 2.5 watt required by the unit might cause a 5 watt total load on the bike. Still not enough to even be a concern. Of course, if you added 20 of these, then it WOULD be a concern.. Or if the bike was at or near its max (70w passing lights, 50 watts trailer lights, 35w heated vest etc) then the extra 5 watt load COULD be a deal breaker. Change all those rear lights for LED, Run HID passing lights and head light (42W each including ballast) and you can get yourself a warmer vest
