First_N_Last Posted July 27, 2012 Posted July 27, 2012 Well... No matter what, it never ends! I just finished getting a pair of Like New OEM mufflers from Hulk They are just like new & I had them installed in less than 30 minutes. My bike is sooooo quiet now. While I was laying on my back tightening the bolts I saw my Avon Venom rear tire. Not only was it terribly cracking on the side walls... it had a bald spot down to the belts with just 11,000 miles. Argh! So now I have to: change rear tire - going back to the Darkside with a Nanking change the rear drive oil change the motor oil clean up everything on the bike ...just so I can go on a short 1500 mile ride in 2 weeks. ...and of course, I'll enjoy every minute of the work - JUST LIKE ALL OF US DO
kwisor Posted July 28, 2012 Posted July 28, 2012 at least you found the tire before you had a problem on the road besafe and have fun bumble bee kevin wisor
First_N_Last Posted July 28, 2012 Author Posted July 28, 2012 just finished buying my Nankang cx668 from Amazon for $68 including shipping. As soon as it gets here... I'll disconnect the Voyager... jack it up... pop the wheel... take it to the dealer (no problem there - lots of Goldwing customers getting CTs mounted)... Then the rest of the maintenance. Whats left??? GPS - no did that clutch upgrade - no did that accessory power - ndt headlight relays - ndt crash bar braces - ndt K grips - ndt K pegs - ndt cup holder - ndt accessory audio plug - ndt car tire - no - doing that again quiet oem mufflers - ndt passing lamps - ndt Avon Venoms - NO - WILL NEVER DO THAT AGAIN!!!!! CD Changer - ndt Speedo Healer - ndt Brake light modulator - ndt Starburst Headlight Modulator - ndt Voyager Conversion - ndt Am I done? Is there no more? That's right... now I get to repaint! It never ends! JohnB
pmelah Posted July 28, 2012 Posted July 28, 2012 Hey what about more safety chrom I didnot see that on the list:confused24:
First_N_Last Posted July 28, 2012 Author Posted July 28, 2012 (edited) OK all... I forgot some... rear HD brake light bar - no did that rear LED brake light bar - ndt all the RSV S style CHROME - ndt Baron tachometer - ndt removed cassette & made storage - ndt 10" tinted windscreen - ndt rain gear - ndt 4 helmets - ndt 4 different armored jackets - ndt higher wattage headlight - ndt ride The Dragon - ndt get a tattoo - ndt - twice (Spider & Dragon) ---------------------------------------- Needs to do!!! paint Voyager fenders with High Impact paint - Need To Do paint Voyager frame with brushed Rustoleum - ntd re-wire all lights on Voyager - ntd check/adjust carb floats - ntd check/adjust valve clearance - ntd change clutch plate to Barrett - ntd win the lottery - ntd get enough money to retire - close, but - ntd mount a FREAKIN LAZER on my helmet - ntd All of this was started by HummingBird. He was kind enough to: - pick me up at the airport - drive me to Adventure HD where I bought my bike in Ohio - helped me change the rear tire - gave me a jack bracket - sent me on my way driving home with my RSV HBird is one of the best! 23,000 miles later... Yes, I'm Abby-Normal when compared with most of the world, but I fit right in here! JohnB Edited July 28, 2012 by First_N_Last
