Marcarl Posted January 17, 2008 Posted January 17, 2008 To take some time, a few tools. a little extra light, and go over your scooter from front to back and make sure all the nuts and bolts are good and tight. Reason why I say this? I have to fix second gear on my scoot and so I got started on it today. The motor is now ready to slide out. In the process I found lots of bolts that should have been tight but instead were soo loose that I hardly needed a wrench to take them out. Engine mounts, tightened last year, bottom side rail,(right side part of frame) tightened last year were my biggest concern. I will now go and check each and every bolt I can find and make sure it's tight, tight ,TIGHT.
Squidley Posted January 17, 2008 Posted January 17, 2008 I'll refrain on saying anything smart alec and just say....good luck and an easy time to you
hipshot Posted January 17, 2008 Posted January 17, 2008 carl! i am beyond , delighted, that i DON'T get snowed in! 'nuff said! just jt
BradT Posted January 17, 2008 Posted January 17, 2008 I'll refrain on saying anything smart alec and just say....good luck and an easy time to you I too will refrain from a comment, but if Redneck or chaos were to read this I am sure they may not. Carl if you need a hand give me a call. Not sure when your tackling it, but I have a busy week coming up, as I will be travelling, maybe we can connect up. Brad
