shifting noise
pmj423
Shifting gears at low rpm will result in a clunk. A clunk into first gear accompanied by a jerk when first starting up after it has been sitting overnight is caused by the clutch plates sticking together. To remedy this just blip the throttle while you have the clutch pulled in before putting the bike in gear. If you won't lug the engine while cruising around town, I don't think you'll hear the clunk while shifting. Try it, you'll be amazed at the difference!
The clunking, to an extent, is somewhat normal. All my RSV's have done it, even the new '08 I had with 1 mile on it when I bought it. As long as your not hearing any additional noises from the gearbox (less the whine of the clutch basket if yours is so inclined) you'll be fine.
