BMW Posted January 15, 2008 Posted January 15, 2008 Alan, I took my wheels into Highlands Yamaha and they put the new Avon's on while I waited. I also had them put a 90 degree valve stem on the front wheel for $10.00 The cost was $30.00 a wheel mounted and balanced. Highlands is located in Countryside.Greased spline's on drive shaft also, changed oil in final drive too. If you need a hand when you do yours call me. Bill.....
dharnie Posted January 15, 2008 Posted January 15, 2008 Honda dlr wants $220 for set OEM Dunlops installed on/off VT1100 Sabre - and can wait & drive it home. Yamaha dlr is running a "special" $5/wheel bal + $100 labor (because they drop the bags, + cost of whatever tires one wants!! Plan on spending 1/2 day with him - if he can get to it right away! I have been riding on & off over 40 years and thank God have had only 1 flat on the rear tube-type tire in a 650 BSA traveling about 65 mph. I was very surprised how controllable the situation was! I did not panic and simply coasted the bike to a stop onto the paved shoulder. I was even able to drive it slowly from an off ramp onto a side road. Found a small shop owner who patched it for $15! (Of course that was back in the 70s!)
pegscraper Posted January 16, 2008 Posted January 16, 2008 Al, do you use stick on type weights, or something else? Where do you get them?
wkboard Posted January 31, 2008 Author Posted January 31, 2008 Hi all, I got my new Avon Venom's from southwestmoto. (What a nice guy to work with!) I found a dealer close to me - Schaumburg Honda/Suzuki. He charged $20 each to mount and computer balance. (with all of the rotors on) Did a nice job, same day service. I replaced the front stem with a 90 degree and had both stems pointed to the right side at a 45 degree angle. should be easier to check wit it on the side stand. ALL of the Yamaha dealers that I checked wanted between $40 and $75 each to do the same thing. (Includeing Chicago Cycle - 72.50 each) I read many posts - here and on Venturerider tech, and learned Oh so much from all of you people's knowledge! Thanks to you all. Good stuff! I also am greaseing everything up - includeing the pins- but could not find Royal Purple grease anywhere. I am useing a new valvoline synthetic moly wheel bearing grease. Good consistency - looks like it should work well. I have many other projects going and the bike looks like a skeleton. 59.99 Harbor freight jack/lift is working well.
